1997 neon help
Old Jun 26, 2005 | 03:19 PM
kkmbrs's Avatar
kkmbrs
Default 1997 neon help
As I hopped in my car to leave a store the other day my car did not want to go more than prob 1mph. Kinda bogging down etc..This lasted about a good half mile and then all of a sudden it drove fine again. My service engine soon light is on now.. This was 2 days ago and since then it has driven fine. Any ideas on what this could be?
Old Jun 26, 2005 | 04:16 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: 1997 neon help
Is ur car an automatic?
Old Jun 26, 2005 | 04:45 PM
kkmbrs's Avatar
kkmbrs
yes it is an automatic..
Old Jun 26, 2005 | 06:41 PM
casper's Avatar
casper
Try flashing out the codes, that will haelp a lot. I can't link it right now, but it is in the general help section OBD I
Old Jun 26, 2005 | 10:35 PM
kkmbrs's Avatar
kkmbrs
I get code 12. I don't know if this helps but that day it was extremely hot outside..
Old Jun 28, 2005 | 07:56 AM
RadarLove's Avatar
RadarLove
12 is usually the first code, and nothing to worry about. 55 should be the last code. Nothing in between?
Old Jun 28, 2005 | 01:56 PM
kkmbrs's Avatar
kkmbrs
Duh, LOL-- I get code 43..
Old Jun 28, 2005 | 06:45 PM
catman22's Avatar
catman22
code 43 multiple cylinder misfire detected. peak primary circuit current not acheived with the maximum dwell time.
Old Jun 28, 2005 | 07:23 PM
kkmbrs's Avatar
kkmbrs
Ok- So what should I do about that. Bring it in or keep driving it. It has driven fine since the one episode..
Old Jun 28, 2005 | 11:07 PM
catman22's Avatar
catman22
reset the pcm, unhook the negative battery cable and wait about 5 - 10 min before hooking back up, it will clear all codes and then you will be able to see if your code comes up again or if it was just a fluke.
