96 SOHC removal
Old Aug 16, 2005 | 04:17 AM
booboo's Avatar
booboo
Default 96 SOHC removal
i have 96' SOHC and i was wondering if any of the accessories have to be removed from the front of the motor in order to have enough clearence in order to seperate the clutch assembly from the crank or if ill neeed to remove the mtx in the process too so far its semed to be a very straighgtforward remove& reinstall it just seems to have only about 2-3 inces of clearence between the strut towers with all the accessories on the front of the motor also i was wondering if there is any different wirin on the "plymouth"neons v. the dodge neons or if they were the same exact setup as i would think
Old Aug 16, 2005 | 07:15 PM
casper's Avatar
casper
Default RE: 96 SOHC removal
What are you trying to do? If you are trying to get at the clutch, you are gonna have to drop the trans. I have done my 98 MTX a few times, I could help you if thats what your doin.
Old Aug 16, 2005 | 08:29 PM
booboo's Avatar
booboo
im actually replacing the motor since i believe i spun a main bearing the other day i was just tryin to figure out if i will need to support the tranny once the motor is out and if any of the accesorys need to be removed from the front of the engine to get it out so as theres enough room to pull it out what i was gonna try was unboltin the clutch assembly from the flywheel and see if that would allow the motor and tranny to seperate enough to be able to slide the motor straight out also i cant seem to get the clip apart that holds the oil sending unit wires in also thanx casper
Old Aug 17, 2005 | 03:42 AM
casper's Avatar
casper
If are pulling the motor, I suggest you just disconnect the half-shafts and pull the motor and trans all together. It will be a lot easier to take the trans off with the motor on a stand.
Old Aug 17, 2005 | 08:08 AM
RadarLove's Avatar
RadarLove
Definitely agree on that. Pulling just the tranny is easy enough without touching the motor. But I wouldn't leave the tranny in while pulling the motor...
You'll have to tilt the passenger side of the motor up and the driver's side down a little to get it out if coming out the top. Removing the intake manifold, battery tray, rad and condenser, and coolant overflow tank will give you a little more play room. Obviously the axles, exhaust manifold, shift cables, and a ton of electrical connectors will have to be undone.
Best of luck!
Old Aug 17, 2005 | 08:55 PM
booboo's Avatar
booboo
so it seems that i will be droppin the half shafts and pullin the tranny too i already have the maze of wiring disconnected i was wonderin if any one would know if theres anydifference in the dodge and plymouth wiring as the replacement come from a plymout neon for what thats worthbut its off to the garage and turn some more wrenches
Old Aug 22, 2005 | 08:12 AM
RadarLove's Avatar
RadarLove
Dodge and Plymouth Neons are identical in every way, except for badging and a couple of letters in the VIN. There may be some differences from year-to-year though. Easy enough to snip and swap connectors if needed though.
Old Aug 22, 2005 | 07:55 PM
booboo's Avatar
booboo
since ive b een draggin my feet(workin on something that will actually pay somethin ) and have yet to actually start droppin my half shafts i was wonderin what would be the simpliest/quickest way to drop em im a big fan of workin smarter not harder and also how the hell does the oil sending unit on the back of the block disconnect im bout ready to say screw savin all the special clips and destroy it due to the irriatation it has given me and thanks for that tidbit there radar
Old Aug 23, 2005 | 06:20 AM
dude402's Avatar
dude402
Just make sure the replacement harness isnt from a 95. the harneses changed from 96 on. its alot easier just to pull the engine and tranny at the same time... i just did it with my 95
