factory tweeter!!
Old Aug 14, 2012 | 02:45 PM
ohioguru's Avatar
ohioguru
Default factory tweeter!!
i have a base 96 neon where the tweeter spots were just filled in with foam. what size tweeters does it take? and will i need shallow mounts? also the wiring harness for them seems to be there but would it just be plug and play?
Old Aug 14, 2012 | 07:54 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I think they are about 2.5". I have made 3.5" work before. I usually just stuck with the factory tweeters in most cases because they are an odd size.
Old Aug 16, 2012 | 11:46 PM
ohioguru's Avatar
ohioguru
looking at it again is it actually a tweeter that goes on the dash facing up to the windshield or is it a small speaker?
Old Aug 17, 2012 | 10:00 AM
I_Ride_Neon
You could almost say its a small speaker. But I think there is a EQ on the speaker to get rid of the lows and mids. I usually stuck with the stock ones if they worked good.
Old Sep 13, 2012 | 10:35 AM
96dohcsportcoupe's Avatar
96dohcsportcoupe
the tweeters from a 300 m will fit and their infinitys so they are better than stock and are a dierect fit
Posted from Dodgeforum.com App for Android
Old Sep 24, 2012 | 07:04 AM
JKat's Avatar
JKat
what year 300 should i be looking for and where are the speakers located on it? simialr place to the Neon.
Old Sep 24, 2012 | 11:46 AM
96dohcsportcoupe
any 300M will work. they are located in the same spot as the neon
Old Sep 25, 2012 | 08:25 AM
JKat's Avatar
JKat
thx, now i have something else to add to the list next time i make a u-pull-it run...lol
