95 Neon Power Issue??? Help!!!
Old Nov 2, 2005 | 02:49 AM
Macloed's Avatar
Macloed
Default 95 Neon Power Issue??? Help!!!
Hi All,
I have 3 Neons 98,96 and 1995. All stock cars. The 95 neon has the least amount of miles on it and looks the best acutally. The problem i'am having is the car don't seem to have the power as the others? It actually seems like it has no power when i accelerate. I checked the cat its not clogged it just seems as if this car doesn't have the pep like the others i own. Only visual difference i see im now a pro is that the air intake looks different on this modle and this one was Mexican. Any idea what is causing this lack of speed & acceleration??
Jim
Old Nov 2, 2005 | 03:46 AM
RadarLove's Avatar
RadarLove
Default RE: 95 Neon Power Issue??? Help!!!
Do they all have the same number of cams? Do they all have the same tranny? All of them stock?
The '95 didn't come with the "scoop" cover going from the front of the car to the airbox, at least not on the SOHC... Mexican or American built won't make a difference, except for the radiator.
Old Nov 2, 2005 | 04:55 AM
Macloed's Avatar
Macloed
They are all stock and correct it does not have the air scoop like the others.
Macloed's Avatar
Macloed
Oh forgot Yes all same Tranny automatic. And all Sohc
Old Nov 2, 2005 | 02:22 PM
casper's Avatar
casper
Try a tune up.
Old Nov 3, 2005 | 11:20 AM
Macloed's Avatar
Macloed
Just did tuneup today same.??
Old Nov 3, 2005 | 01:05 PM
whyte69's Avatar
whyte69
define a tune-up. Did you check the spark plugs, wires, air filter, fuel filter, oil filter? Any error codes? Tried a bottle of Fuel Injector Cleaner?
Did the 95 suddenly lose power that it had originally?
Old Nov 4, 2005 | 08:27 AM
bossmankx's Avatar
bossmankx
did tune up include fuel filter, plugs, plug wires?? If so then try a can of sea foam (comes in red and white can at autozone or napa or similar store)
Start the car, remove the vaccuum line from the brake booster, then pour about 1/3 of the contents of the can into it. Promptly turn the car off and let it sit for 10 - 15 minutes. Start it up and run throught he rpm band / go for a drive till it stops smoking. Excessive smoke is normal, DON'T DO IN GARAGE.
I first thought my 96 neon was a real dog, and this stuff and along with aforementioned parts really helped it out.
Old Nov 6, 2005 | 03:39 AM
RadarLove's Avatar
RadarLove
I'd start looking on the tranny end then. I'm definitely not an auto tranny guy though... Fluid and belts and whatnot. Shops here only charge $30-40 for an auto tranny tune-up.
Old Nov 6, 2005 | 05:20 AM
casper's Avatar
casper
ORIGINAL: RadarLove
LOL, where do you live??? A fluid flush and fill with a filer is $75 here. A band ajustment is another charge jhsut for the record, ususally $100+
