witch block
i have looked in alot of resorcies and can't seem to findout witch block was use stock on the street neon, i have a 96 coup and am trying to work out if a crate stroker or building one is cheaper, but crates are offered in both short and long blocks with about a 3K dif
I find the Warlock and Wizard blocks better myself ;-) j/k
Short block has no cylinder head or oil pan. You use your cylinder head. A long block is supplied with a a cylinder head installed.
Our Short & Long blocks are both balanced and blueprinted. Our long blocks have our Stage 6 cylinder head with cams installed and degreed for maximum performance.
420A = Avenger, Talon, Eclispe, Sebring Coupe 4 cylinder
ECB = Neon SOHC 95-02 Except R/T
ECC = Neon DOHC 95-99
No 420A version was ever used in a Neon, the cylinder head and pistons are backwards.
ORIGINAL: Gary Howell
yeah, that is the "rumor" i have guys all the time askin if mine is the 420a and i just laugh, alot of reports are sayin the mitsu engine is the neon dohc but backwards, but it is not true. block is close but not the same.
Trending Topics
420A is the name Mitsu gave the long block in the Eclipse. D4RE (DOHC) and S4RE (SOHC) are the names Chrysler gave the Neon long blocks. Other than the '95 SOHC (stupid bearings...), all the short blocks are the same, just different pistons.
ORIGINAL: RadarLove
*EDIT* Please do not advertise other forums on DF.
