i get a code 11, and auto zone said it means it skipped a tooth, so i put on a new timing belt, but I know nothing about how to adjust the timing. I just put it at tdc and swapped belts...
yo seriously dude..18 SECONDS!??!!!DAMN!!!!!!!!You need a MAJOR tune up...i have 2 1995Neons...1 is manual and the other is auto...and like casper said...u shouldn't be runin anymore then 12secs..and even then there's a prob!!!!
You probably have bad compression due to the timing belt skipping a tooth and then bending some valves. You didn't say anything about replacing the valves or checking compression. All the tune-ups won't help if you have bent valves.
