97 wireing issue
Old Jun 12, 2006 | 06:33 PM
rpernack's Avatar
rpernack
Default 97 wireing issue
My wife and i were on our way home from work when the car died on us. i left the car there over night. when i went back the next day the only issue that i could find was that the fuel pump fuse was blown and every time i put a new one in it would blow. i put a new fuel pump in and it still blows. then come to find out there was a short in the wireing some were. we can't find the short. all the wires are connected and there are no bare wires that are touching anything that they shouldn't.
first off has anyone eles had this issue and if so how did you solve it?
second i was thinking of getting a new wireing harness, does anyone know were i can get one that is in tac. the only ones that i could get were all busted up?
Old Jun 12, 2006 | 06:59 PM
dogdaysunrise's Avatar
dogdaysunrise
Default RE: 97 wireing issue
where abouts are you? I have one here that I would be willing to part with. Its out of a 95 neon however.
I live in Winnipeg, MB, Canada
Let me know
Old Jun 12, 2006 | 07:03 PM
rpernack's Avatar
rpernack
i am in Phoenix az.
what whould you sell it for including shipping?
Old Jun 12, 2006 | 07:53 PM
das2123's Avatar
das2123
Blown fuses usually relate to bad grounds. Have you checked under your battery tray for corrosion? There may be some acid there that is eating away at the wires.
Old Jun 12, 2006 | 09:24 PM
rpernack's Avatar
rpernack
i have not seen any corrosion but there is a wire that is conected to a plastic part that is connected to the battery case both are plastic.
Old Jun 12, 2006 | 09:59 PM
dogdaysunrise
how much of it do you need? just the box? or do you want all the wireing with it?
Old Jun 12, 2006 | 10:15 PM
spudsterier's Avatar
spudsterier
i had the smae problem for a while on one car the pcm was bad....and on the other car i had to start unplugging all the sensors one by one, then replace the fusesafter each sensor...time consuming and went through about 70 fuses...then found out it was my downstream o2 sensor.....is your car a 95? if not the wire harness would be different and dohc or sohc?
Old Jun 12, 2006 | 10:21 PM
rpernack's Avatar
rpernack
all the wiring
