SRT4 swap almost complete
Old 06-20-2006, 07:54 PM
99SRT4's Avatar
99SRT4
99SRT4 is offline
Default SRT4 swap almost complete
SRT4 SWAP GOING GOOD SO FAR
[IMG]local://upfiles/36911/40E5E4FA514446ACA6C1D7F7BB39EE22.jpg[/IMG]
[IMG]local://upfiles/36911/F09821A2119247E9B61BA2EF1233993E.jpg[/IMG]
[IMG]local://upfiles/36911/AD7B4BF29FE04D2EBF5B11297A0D3475.jpg[/IMG]
[IMG]local://upfiles/36911/D79A52B6D54949DFA1145B1D4513650E.jpg[/IMG]
Old 06-20-2006, 09:18 PM
das2123's Avatar
das2123
das2123 is offline
Default RE: SRT4 swap almost complete
Looks very nice!!!! What are you doing anout the PCM?
Old 06-20-2006, 11:52 PM
99SRT4's Avatar
99SRT4
99SRT4 is offline
stock R/T PCM I was going to use the my MOPAR PCM I was told that it would not work.Can I use the stock fuel pump. MODERN PERFORMANCE told me to get a fuel pressure regulator from a 2000 and up neon or the 255 fuel pump
Old 06-21-2006, 01:51 AM
das2123's Avatar
das2123
das2123 is offline
If you use the stock PCM, you will need a MAP clamp or missing link won't you? I would think the Walboro pump would be enough.
Old 06-21-2006, 02:24 AM
99SRT4's Avatar
99SRT4
99SRT4 is offline
what do you mean by map clamp, and why won't the 255 fuel pump be enough?
Old 06-21-2006, 02:28 AM
das2123's Avatar
das2123
das2123 is offline
The stock PCM cannot see boost without freaking out. You have to go around it somehow, like a MAP clamp. See the link below for more info...
http://www.fwdmopar.com/sites/dennis/howto.html
Most people who do the SRT engine swap just go with a Stage 1 PCM that hasn't seen the Sentry.
I said the Walboro would be enough.
Old 06-21-2006, 06:02 AM
99SRT4's Avatar
99SRT4
99SRT4 is offline
will it be safe use
Old 06-21-2006, 12:07 PM
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: 99SRT4
will it be safe use
Will what be safe?
Old 06-22-2006, 01:03 AM
99SRT4's Avatar
99SRT4
99SRT4 is offline
will the AOBE be safe
Old 06-22-2006, 01:05 AM
99SRT4's Avatar
99SRT4
99SRT4 is offline
thank you for all the help
Quick Reply: SRT4 swap almost complete
