Back Speakers
Old Jun 23, 2006 | 01:07 AM
95neoncustom's Avatar
95neoncustom
Default Back Speakers
I ripped up the carpet in the back and found 2 wires were the speaker can go are they usuable or do i have to run new wires
Old Jun 23, 2006 | 01:45 AM
spudsterier's Avatar
spudsterier
Default RE: Back Speakers
should be useable, as long as they are speaker wires, if they dont reach, just extend them
Old Jun 23, 2006 | 02:50 AM
95neoncustom
im not sure if there speaker wires thats the problem
Old Jun 23, 2006 | 03:39 AM
dogdaysunrise's Avatar
dogdaysunrise
what colors are they? quick way to check is compair the color to what color it says in your haynes book.
Old Jun 23, 2006 | 04:22 AM
FuzzRacer's Avatar
FuzzRacer
Good Idea, ive ripped up the back carpet once and saw something but was protected by plastic, I think the speakers run on the top side like the trunk light does I could be wrong, but the manual should be able to clear it up
Old Jun 23, 2006 | 09:30 AM
spudsterier
if the wires run ontop of the rear deck then they should be the speaker wires, the only other ones that run ontop of there should be the trunk light, but that one should be in a plastic sleeve
Old Jun 23, 2006 | 12:33 PM
bishop's Avatar
bishop
on mine when i took the carpet off the wiers were right there for the speakers it was a while ago but from what i remember they were wrapped ina black tape .
Old Jun 23, 2006 | 02:46 PM
pimpberetta's Avatar
pimpberetta
Speaking of the black tape. Does it look to you as if its hockey stick tape. Like the same kind of material. BEcuase mine sure looks like it, and its over the entire electrical system. Kinda cheap if you ask me.
Old Jun 23, 2006 | 07:46 PM
ScrapYurImport's Avatar
ScrapYurImport
When i changed my speakers the wires were on the inside of the trunk. There should be two plugs that go in the back of your speakers.
Youll have to cut the plugs off and strip the wires. Then you shough be able to wire them to just about anything.
I left the carpet in mine i just cut holes and put the covers over top of the speakers it looks awsome I think.
Ill try to post a pic.
Old Jun 23, 2006 | 08:03 PM
ScrapYurImport
Ok heres the pic of myback speakers in my 95.
It was a pain in the *** getting them to fit correctly.
They look pretty cool I think.
[IMG]local://upfiles/33097/C5E3BD99284B4AE2BA83F94588F9DEF5.jpg[/IMG]
[IMG]local://upfiles/33097/2301FD9FC89347E182C53565A0C83CD0.jpg[/IMG]
