this might be a dumb question
Old Jun 24, 2006 | 11:01 PM
streetbikr600's Avatar
streetbikr600
Default this might be a dumb question
i just bought a crazy head unit that putts out 250 watts and a 300 watt amp with one 12" kicker sub and my car is slow as hell i was wondering if i run two batteries will car run normal agian, and has any one here run two batteries
Old Jun 25, 2006 | 01:11 AM
racerx55's Avatar
racerx55
Default RE: this might be a dumb question
i dont think the stereo system would cause your car to be slow as hell, id check elsewhere for other problems, only reason you would need 2 batteries is if you were running way more power than you have and killing the battery with the car running, then youd also need a higher output alt.
Old Jun 25, 2006 | 01:34 AM
spudsterier's Avatar
spudsterier
i used to have a stereo in my neon that consisted of a pioneer deh-p9300 head unit, 2-500 watt orion extreme amps(for interior speakers: 2 audiobahn 6x9's, audiobahn 6.5 in. component set with 1 inch tweeters, and audiobahn 3.5in. dash speakers) and 1-2400 watt audiobahn amp, pushing 4 audiobahn 1206 flame-Q 12's and the audiobahn amp was running at 1/4 ohm....stock alternator, and farm and fleet battery....loudest stereo you would hear in the trunk of a neon, and only made the car stumble when the bass hit really hard
Old Jun 25, 2006 | 12:07 PM
das2123's Avatar
das2123
ORIGINAL: streetbikr600
bosh platnium 4
Don't know about the battery problem, but those platinums will cause your car to run like crap.
Old Jun 25, 2006 | 11:31 PM
pimpberetta's Avatar
pimpberetta
Yeah, change those spark plugs to the stock ones and it will most likely change it up a bit.
Old Jun 26, 2006 | 08:34 AM
racerx55's Avatar
racerx55
platinum plugs made my race neon run like total ***, el cheapo champion plugs run just fine, my race car is a 96 sport DOHC with a 98 r/t 5 speed, (used to be automatic) has the original plug wires, (85,000 miles of use plus half a race season of abuse), new champion plugs about 200 laps ago- 2 1/2 straight pipe comes out in front of the left rear wheel, K&N filter in the stock airbox, 100% original and stock and it runs great, were not allowed any mods in that race class at all, so i run what i got and i find evry last little bit of power i can, normal plugs ran teh best, if you have the steel fuel tank, change the fuel filter, and check the pressure - these things are bad about weak fuel pumps, they will run, but start hard and run weak - lose those damn overpriced spark plugs, set the gap on champions at .035" and stay away from 87 octane, give that a shot see what you come up with
Old Jun 26, 2006 | 11:28 AM
DevilsReject's Avatar
DevilsReject
Noob Assassin
racerx55 and das2123 are absolutely correct.
The Bosch Platinum plugs are absolute crap. I got free sets for my Beretta Z26 and it ran like absolute crap. Went back to the el cheapos and it ran fine. I'd change them out asap. I dont know why people associate the word Platinum with better quality. Check your fuel filter....but also check your air filter and have your fuel injection cleaned out. Those 3 things alone can help fuel efficiency and also may correct your problem possibly.
Your system doesnt push out nowhere near anything warranting a second battery. I ran a 1200w amp, two 10" subs, and a 250 watt headunit on a stock alternator/battery setup. If your concerned with power loss due to a sound system....you can always upgrade the alternator to a higher amp one. They make heavy duty alternators. I used to have a car with a secondary battery for my sound system....and let me put it like this....I was pushing 4000w...and 2 12" Vega Strokers....you arent even coming close to needing the battery power I needed.
Old Jun 26, 2006 | 12:10 PM
das2123's Avatar
das2123
ORIGINAL: racerx55
Could you slip in an ATX TB??? It's still stock
ORIGINAL: DevilsReject
They do work well with some cars, just not the waste spark ignition that the neon has. My wife's 2000 sebring requires platinums for longevity, becasue they are a PITA to replace. You have to pull of the upper intake manifold to get to them.
Old Jun 26, 2006 | 12:41 PM
DevilsReject
Noob Assassin
ORIGINAL: das2123
Hehehe, you did take a look at the car in my signature right? I have to do the exact same thing to change my plugs too! [:@]
Old Jun 26, 2006 | 12:44 PM
das2123's Avatar
das2123
ORIGINAL: das2123
I didn't even notice that
