pull up the bottom coushin..there is just two clips.......then there are two T-60 torx bolts that hold down the seatblelt and the lower back of the seat....then just lift up the back and pull it out....
PB Blaster is a penetrating lubricant, you can get it at any automotive store, prolly hardware stores too.. Invest in it, it will save alot of work in the future! You will come to love it... Just dont get it in your eye.. doesn't feel too good ( I have experience... )
Mine were so rusted in I and my torx is a 3/8" drive so I ended up buying a 1/2" - 3/8" adaptor and using a breaker bar to get it off and it was still a fight.
on one of my cars it was so stuck that i welded the bit to the bolt and got it out that way...on the other car i just used a grinder and ground it off...then just left it
Go to walmart or a tool store and pic up a Dremmel multi purpose tool, they can saw, drill, grind, sand , polish and all kinds of other usefull things. good tool, not very pricy and easy for anyone to use good luck !!!
