EGR Valve
RE: EGR Valve
ORIGINAL: IGottaFreeNeon
If you pull off the egr valve and block it off, will you get a code?
Will it give you more horsepower or help you gas mileage?
RE: EGR Valve
ORIGINAL: NEONRT98
The kit from NeonGoodies.com offers a resistor looking mechanism, will that help with the code 32? Will it hurt anything if the car is throwing that code?
RE: EGR Valve
Yes, I confirmed it. If you read the previous post, I did it on my car. The only thing that I was not sure about was the compatablity between the dohc and sohc, however modern sells that same kit for both so I am about 98% sure it will work on the first gen dohc as well.
The 2nd gen head and the first gen head are identical. I checked the casting numbers and part numbers with Dodge. The same part number (bare head) fits all years sohc '94 to '02.
