popping in exhaust
Old Aug 28, 2006 | 04:04 PM
spudsterier's Avatar
spudsterier
Default popping in exhaust
a couple of times a day when im driving the car sounds like it backfires.....only when i start goin from a stop.....as soon as i let out the clutch when shifting into second it pops and boggs down.....but just for a second..then its perfectly fine....im not sure if its the cat, o2 sensor, or sumthing with the egr...or what, any ideas???...
and no i dont know if its throwing a code for it because the CEL is always on.....if i get a chance later when i get off of work i will bring the computer out there and check the light
Old Aug 28, 2006 | 05:23 PM
95neonriceeater's Avatar
95neonriceeater
Default RE: popping in exhaust
exhausts do that sometime
my stock DOHC does that
usually aftermarket exhausts do it
my friend's rice rocket use to do it all the time
i think its just with the better flowing exhausts tho
my SOHC exhaust never did it
Old Aug 28, 2006 | 07:54 PM
spudsterier
oh believe me, its not the axhaust just doin it.....sumthing isnt working right....this sounds like its backfiring...but just once and a while and only one time when it does
Old Aug 28, 2006 | 09:02 PM
NEONRT98's Avatar
NEONRT98
Its not backfiring into your intake manifold, is it?
Old Aug 29, 2006 | 12:50 AM
FuzzRacer's Avatar
FuzzRacer
Check the Egr system, I had probs with that once and the egr was a possible problem, in the end it wasn't but it will cause the probs you described.
Old Aug 29, 2006 | 01:02 AM
spudsterier
im not all that horribly worried about it...its just more annoying then anything.....and no, not into the intake, out the exhaust
i might just have to switch out the egr to check(i think i have 5 or 6)...
i never got a chance to hook the computer up to the car yet, but maybe tomorrow...then if its throwing a code i will know
Old Aug 29, 2006 | 01:04 AM
daveyg's Avatar
daveyg
If it's a really free flowing exhaust, it will do it at lower rpms, it's called scavenging, if your exhaust is built for huge HP, and has a 2.5-3" exhaust on a N/A car, the exhaust gasses will swirl back, and pop.
Old Aug 29, 2006 | 01:14 AM
spudsterier
nope...stock manifold, still has the cat, stock pipe size...the only difference is the vibrant muffler.....this only started happening about a week ago
Old Aug 29, 2006 | 01:54 AM
das2123's Avatar
das2123
What about your plugs???
Old Aug 29, 2006 | 01:58 AM
spudsterier
changed them within last 20,000 miles....that shouldnt be the problem because i got the GOOD plugs....i used the bosch platnum+4's cost me alot of money and its a good name so that isnt the problem.........j/k i used the champions...wanted to get ngk's but they didnt have any instock
