Wheel Noise
Old Aug 29, 2006 | 10:08 PM
NeoAngelo's Avatar
NeoAngelo
Default Wheel Noise
I have a modifies 1997 Dodge Neon and I have been getting noise from the rear driver's side tire whenever I hit a bump, pothole, etc. I cannot locate the exact source of the problem. Any suggestions as to where to look?
Thanks.
Old Aug 29, 2006 | 11:53 PM
spudsterier's Avatar
spudsterier
Default RE: Wheel Noise
tie rod or ball joint.....jack up the front of the car and wibble the wheel....while wiggling it, watch your outter tie rod and lower ball joint and see if they move
Old Aug 30, 2006 | 12:35 AM
das2123's Avatar
das2123
ORIGINAL: spudsterier
Does that work for the rear as well?
Also check your strut mount.
Old Aug 30, 2006 | 01:06 AM
spudsterier
i dont know if it does....ive never had any problems with my rears, only the front so thats all i know alot about.....compared to the rears
Old Aug 30, 2006 | 01:09 AM
das2123's Avatar
das2123
I only asked, because the OP said the sound was coming from the driver's side rear area.
Old Aug 30, 2006 | 01:17 AM
spudsterier
i musta missed that then.....ive been around alot of paint fumes today so my brain isnt working like i want it to right now
hey, OP theres another abreviation for ya
Old Aug 30, 2006 | 01:21 AM
das2123's Avatar
das2123
Thats funny.
Just added it.
Old Aug 30, 2006 | 01:23 AM
spudsterier
well its about time you start doin some moderator work
actually, now that i think about it, it would work for the rear to see if its a hub bearing
Old Aug 30, 2006 | 01:26 AM
das2123's Avatar
das2123
Hey, I'm working on a post that will have pics of the neon's sensor locations...like CPS and IAC and so on.
Old Aug 30, 2006 | 01:31 AM
spudsterier
need any pictured let me know.....i have the motors sitting in the garage that can get pics pretty easily
