Shifting into reverse is wierd
Old Sep 13, 2006 | 01:37 PM
xdeathwishx's Avatar
xdeathwishx
Default Shifting into reverse is wierd
This is more of an annoyance than a serious problem but here goes:
I can shift into all gears perfectly fine, but reverse is kind of wierd. sometimes i have to like ease it in there, and it doesnt really go into gear until the shifter is pretty much all the way back. Sometimes when it does go in, i can hear the gears kind of grind for like a split second and it shakes and then goes in. That only happens when i do it carelessly not keeping in mind this problem, so its not like im running around grinding my gears every day. Hence this isnt critical but ive always wondered what causes these problems...
Old Sep 13, 2006 | 01:49 PM
das2123's Avatar
das2123
Default RE: Shifting into reverse is wierd
FSM Says:
Hard shifting may be caused by a misadjusted crossover cable. If hard shifting is accompanied by gear clash, synchronizer clutch and stop rings, or gear teeth may be worn or damaged. Misassembled synchronizer components also cause shifting problems. Incorrectly installed synchronizer sleeves, struts, or springs can cause shift problems.
Your reverse gear may be getting worn a bit.
Old Sep 13, 2006 | 03:15 PM
xdeathwishx
i would tend to think it was the misadjusted cable. I dont normally get the gear clash, just when i dont have it all the way in and let up on the clutch, which is obviously my fault and not that of the car. Is that thing hard to adjust?
Old Sep 13, 2006 | 03:16 PM
xdeathwishx
by the way, i ordered maximum boost. cant wait to get it.
Old Sep 13, 2006 | 05:07 PM
95neonriceeater's Avatar
95neonriceeater
i have the same problem
when i put my short shifter in its extremly hard to put it in reverse sometimes
sometimes its easy
and sometimes its a ****ing bitch!
Old Sep 13, 2006 | 05:46 PM
xdeathwishx
is yours hard as in, takes force to put it into reverse? or hard as in difficult? Mine goes in nice and easy, just have to do it a certain way.
Old Sep 13, 2006 | 05:54 PM
tomthedog's Avatar
tomthedog
i have about 1k on my new clutch and have the same prob. don't matter if the clutch is all the way in or not. L/R cable is good, front to rear bushing on the MTX is bad. the slower i shift the better it goes. i DO know the guy who had it before me thrashed the heck out of it, it had 84k when i got it and the clutch was GONE. BTW 96 sohc mtx.
Old Sep 13, 2006 | 06:04 PM
xdeathwishx
ORIGINAL: tomthedog
Thats exactly how mine is. good description.
Old Sep 13, 2006 | 06:38 PM
shnormo's Avatar
shnormo
Change the tranny fluid out. Don't use ATF like the dip **** dealer****s and go for the synchromesh. It's $9.99/qt at http://www.Amsoil.com and keep in mind this is a full synthetic and it should never have to be changed out again. The synchromesh gears will love you.
Old Sep 13, 2006 | 06:49 PM
das2123's Avatar
das2123
ORIGINAL: shnormo
I think he drives an MTX not an ATX. ATX fluid doesn't belong in a manual tranny!
