new neon, bad engine, bad engine-*smack*
Old Nov 16, 2006 | 06:12 PM
  #21
FastNeon84's Avatar
FastNeon84
Default RE: new neon, bad engine, bad engine-*smack*
if you have 3k to spend, u might be better off rebuilding the engine you have, or find another DOHC motor and building it up, then swap it when its ready. you can get performance rebuild kits on http://www.modernperformance.com, or http://www.howellautomotive.com. the rebuild kits cost anywhere from 1000-1200, each for the top and bottom end. that way if u do that, your engine will be able to take alot more abuse..if or when you turbo it...15-20psi you can run on a fully built 420A without problems...u maybe can go a few pounds higher if you decide to take it to the track one day A friend of mine has a fully built DOHC sport boosting 27psi with a HAHN stage 3 turbo kit when he takes it to the track, and running low 10s in the quarter. so its all up to you man, if i was you, rebuild the engine you got, then you wont have to worry about no electrical rewiring and tracing down shorts and all that other crap.
Old Nov 16, 2006 | 06:20 PM
  #22
neonakusa's Avatar
neonakusa
ok fastneon84 is cool thx for the links cuz thats exactlly what I'm going to do!
Old Nov 17, 2006 | 11:37 AM
  #23
das2123's Avatar
das2123
ORIGINAL: neonakusa
fourth just out of couriousity is it possible to make my front wheel drive neon rear wheel drive?
If you have enough time, money, fabrication/welding skills and want to do alot of troubleshooting, then yes it's possible.
ORIGINAL: FastNeon84
Too bad that ISN'T what is in our neons!!
Old Nov 17, 2006 | 12:23 PM
  #24
fullbuilt's Avatar
fullbuilt
hes right its alittle out of your price range to build one up after spending about $1200 for someone to install it or more for an srt4 swap you may be hard pressed to find an srt4 motor in your price range. however if you find a good sohc motor and put it in to your dohc you will up your compression and ive noticed they give nice power for very little money however going turbo would no longer be an option.
Old Nov 17, 2006 | 12:39 PM
  #25
das2123's Avatar
das2123
ORIGINAL: fullbuilt
You think they SOHC motor is better for a turbo than the DOHC??
Old Nov 17, 2006 | 01:18 PM
  #26
fullbuilt's Avatar
fullbuilt
that would be the part about the turbo not being an option. however the sohc does have some good qualitys. but dohc would work better with a turbo.
Old Nov 17, 2006 | 01:22 PM
  #27
FastNeon84's Avatar
FastNeon84
o well sucks for me[&:]...im not looking for a jet on wheels, but just looking to do mid to low 12s, and ill be satisfied.
Old Nov 17, 2006 | 01:26 PM
  #28
fullbuilt's Avatar
fullbuilt
you should be able to make 12s sohc or dohc you can get alot better than that with ether one.
Old Nov 17, 2006 | 01:50 PM
  #29
das2123's Avatar
das2123
ORIGINAL: fullbuilt
I've seen a 12 second all-motor neon before.
Old Nov 18, 2006 | 11:19 AM
  #30
FastNeon84's Avatar
FastNeon84
all motor sohc or dohc das?
anyways i was in the neons.org forum and some guy told me he is running 10psi on his stock bottom end for 2 yrs, and had it to 12psi a few times..he just said he had it tuned right..[&:]..i dont know about that though...dont want to take the chance to blowing my engine and doing it twice...
