new neon, bad engine, bad engine-*smack*
Old Nov 18, 2006 | 02:31 PM
  #31
Whatsrt4's Avatar
Whatsrt4
Default RE: new neon, bad engine, bad engine-*smack*
Dito--pm me
ORIGINAL: BlackRT?
ORIGINAL: neonakusa
Ok I've read just about every post in the forum and I'm still confused! Keep in mind I'm not real familiar with the modern comdustion engine in these new fangled cars- J/K but here's it goes...
1. My engine has 138,000+ miles on it a messed up piston (piston rod and rocker arm are held by a screw, my screw is broken), not sure which one
2. I have about $3,000 at my disposale
3. Rebuild it or replace it ( we can rebuild you, make you faster, stronger, we have the technology! )
4. If replace, which engine would be the best?
5. THX!
I have a complete Dohc motor for sale in the classified section if your still looking for a motor.
  #32
das2123's Avatar
das2123
ORIGINAL: FastNeon84
all motor sohc or dohc das?
SOHC [sm=smiley16.gif]
Old Nov 18, 2006 | 02:34 PM
  #33
FastNeon84's Avatar
FastNeon84
wow
hey my bad man, i didnt mean to put that list that other forum on this site..
Old Nov 18, 2006 | 02:48 PM
  #34
Whatsrt4's Avatar
Whatsrt4
Allmost done srt swap ( CAN NOT BE DONE IN 3 DAYS) Try 3 months,ok maybe a little less[:@].You could for 3 grand build your engine up nicely with a low boost turbo ( 6-8lbsboost) .I've heard that if you use two head gaskets and 5lbs extra torque on head bolts(studs are better yet)your engine will even last for a reasonable amount of time.But to do it in 3 days ???,planning is everything. I was running a low boost turbo before swap and it was a blast-,but as you know more is better
ORIGINAL: neonakusa
5. THX!
