plugs+oil?
Old Oct 6, 2006 | 09:39 PM
lateralus823's Avatar
lateralus823
Default plugs+oil?
Alright so i was looking under the hood of my neon and i decided to take them plug things that go over the spark plugs off and upon inspection it looked to be like there was oil in the little wholes with the spark plugs. I havnt the slightest clue about engines and such and i was wondering what could be the cause?
Old Oct 6, 2006 | 09:44 PM
ZiggyNeon's Avatar
ZiggyNeon
Default RE: plugs+oil?
check these threads out should help:
plug and oil?
plug and oil 2
Old Oct 6, 2006 | 09:56 PM
lateralus823
Wow thanks heaps man!
Old Oct 7, 2006 | 07:02 PM
das2123's Avatar
das2123
Yep, spark plug tube seals need to be replaced. You can get a valve cover kit for about $20.
Old Oct 7, 2006 | 09:21 PM
lateralus823
Now how much do you think roughly labor should cost and will i run into any problems if i dont get it fixed soon?
Old Oct 8, 2006 | 05:28 AM
NEONRT98's Avatar
NEONRT98
If you are slightly mechanically inclined, you can do it yourself and save a ton on labor! But if not, it shouldn't cost more than an hour of labor! I know alot of places will charge 1 hour minimum of labor
Old Oct 8, 2006 | 04:04 PM
das2123's Avatar
das2123
ORIGINAL: lateralus823
Do it yourself and save the money and feel good about yourself. HERE is a link for a how-to on a SOHC, but the DOHC should be the same.
Old Oct 8, 2006 | 11:19 PM
dj_mars's Avatar
dj_mars
a valve cover gasket set is what u need and to change that is nothing 10 bolts to take off with 10 mm socket torch back to 75 lbs. the only thing u will need that will make it easyer is a socket thats a little smaller than the spark plug tube gasket the donut lookin one and knock them out....cuz prying them out can damage the slots were they go and wont seal back right
Old Oct 9, 2006 | 11:42 AM
das2123's Avatar
das2123
ORIGINAL: dj_mars
I think you mean "torque" to...and it would be 105 in.lbs not 75!
Old Oct 12, 2006 | 12:12 AM
dj_mars's Avatar
dj_mars
yeah i never was a good speller but i a guy at joliet dodge told me thats what he torqued them to if its 105 then its good to know the real lbs
