My Neon has no fire
Old Oct 8, 2006 | 04:16 AM
redhawk4701's Avatar
redhawk4701
Default My Neon has no fire
I have a 96 Neon 2.0 SOHC,I just redone the head and put a new timing belt on it,plus new cam and cranck sencers.It started the first time and ran for about 2 minutes and then stoped running.And when I try to start it the plugs fire 1 time and then wont fire aftere that.Could the coil gone bad even when it was working just fine before all the repairs?
Old Oct 8, 2006 | 04:27 AM
NEONRT98's Avatar
NEONRT98
Default RE: My Neon has no fire
Yep, thats possible. Check it. If you have a Haynes manual, it tells you how in there. I would just buy a new coilpack, dont fart around with the ones from a junkyard. You are liable not to get a good working one in my experience.
Old Oct 8, 2006 | 04:39 AM
redhawk4701
Thanx I'll try that.But what Im afraid is the cost.Everything on it has cost $80 or more.
Old Oct 8, 2006 | 06:06 AM
racerx55's Avatar
racerx55
make sure your crank sensor isnt cracked, and checkit, just because its new doesnt mean its a good part...
Old Oct 8, 2006 | 11:24 PM
dj_mars's Avatar
dj_mars
yep id check the crank sensor and if ur gonna spend 80 bucks for a new coil id go to autozone and have them order u a msd blaster coil its 10,000 volts over stock...but make sure u know what pins u have round of flat most sohc ive seen are round but check to be sure
Old Oct 10, 2006 | 03:04 AM
redhawk4701
Thats what I orderd today.I'll lrt you know if it worked or not as soon as I get it...thanx everyone
Old Oct 11, 2006 | 04:50 PM
redhawk4701
ok heres whats happening now...I just put a new coilpack on the car and when I started it spit out the intake so I cecked the timing belt and reset it and theres no fire.Now Im looking at the PCM.
Old Oct 11, 2006 | 07:15 PM
redhawk4701
I installed a new computer and still no fire.
Old Oct 12, 2006 | 02:57 AM
redhawk4701
OK....I used a test light to see if power is getting to the coil and its getting power to it but it wont fire the plugs.Now I am thinking that the coil isnt grounded so I grounded it and still no fire.but heres the list of what I have done...put new crank and cam sincers and a new coil and new plug wires plus a new PCM. theres a code 12 witch is just that the battery has been desconnected since the last 50 key cycles.
Old Oct 12, 2006 | 10:09 AM
racerx55's Avatar
racerx55
are you gettin reference signal to the coil? if you have that plus power the coil is most likely bad
sounds like you could have a wiring issue
