Battery light/Idles high
Old Oct 9, 2006 | 10:22 PM
MercSoldier's Avatar
MercSoldier
Default Battery light/Idles high
Hey Everyone, i have a problem with the battery light coming on and draining the battery if the cables are left on. I Changed the alternator and it still runs awkward. It sometimes idles high, (2-2 1/2 rpms) but always drops when i come to a stop. I just rescently upgraded to some 2 gauge battery cables and ever since then ive been having problems. The car starts fine, idles fine, drives fine. But when i come to a stop it revs up, and the battery light remains on. Any suggestions?
Old Oct 9, 2006 | 11:23 PM
spudsterier's Avatar
spudsterier
Default RE: Battery light/Idles high
when the battery light comes on its just saying that sumthing isnt right with the charging system......generally the car will rev higher at a stop because the alternator is trying to charge the battery...if the battery had a decent amount of charge in it, then the car wouldnt rev high......
is sumthing not tight all the way, or are the clamps dirty????
sumthing in the new wiring must be shorting out to cause it to drain the battery
Old Oct 10, 2006 | 01:32 AM
slow_hemi's Avatar
slow_hemi
there is a battery temp sensor located on the bottom of the battery tray that will cause the batt. light to come on and its easy to forget to reconnect it if youve had the tray out
Old Oct 10, 2006 | 01:43 AM
NEONRT98's Avatar
NEONRT98
I know it sounds stupid... but make sure your belts are still on!! Its possible the belt shredded! That woudl make it rev like that, I experienced the same thing myself!
Old Oct 10, 2006 | 02:10 AM
FyreDaug's Avatar
FyreDaug
ORIGINAL: slow_hemi
Is that what that sensor is? Battery temp? Lawl, well my battery is in the trunk now. I just ziptied that sensor to some wires in the engine bay. What should I do with it? If it pop the sensor off it wont sense anything right? Will it give me a CEL?
Old Oct 10, 2006 | 09:58 AM
spudsterier
i cut off the front of my battery tray for my iceman intake and just left the sensor wedged in by the radiator
Old Oct 10, 2006 | 02:32 PM
slow_hemi's Avatar
slow_hemi
you will need to keep the sensor plugged in so you dont get a CEL
Old Oct 10, 2006 | 04:21 PM
FyreDaug's Avatar
FyreDaug
So its fine how ive just got it ziptied in the engine bay? Its not exactly sensing battery temp.
Old Oct 11, 2006 | 12:50 AM
spudsterier
doesnt matter....just as long as its plugged in
Old Oct 11, 2006 | 02:15 AM
rrwertz's Avatar
rrwertz
yep.
my battery is in the back.
