FPR...?
Old Oct 17, 2006 | 11:41 PM
Ice_Man_67's Avatar
Ice_Man_67
Default FPR...?
Ok, quick question, which is the inlet and outlet...
[IMG]local://upfiles/17990/EE3C842D94EA42C1B7DD9F712A0EC946.jpg[/IMG]
Old Oct 18, 2006 | 01:05 AM
spudsterier's Avatar
spudsterier
Default RE: FPR...?
there wasnt any directions????
Old Oct 18, 2006 | 01:20 AM
Ice_Man_67's Avatar
Ice_Man_67
Default RE: FPR...?
nope, nutin
Old Oct 18, 2006 | 01:21 AM
spudsterier
Default RE: FPR...?
sorry cant help you out
Old Oct 18, 2006 | 01:42 AM
FuzzRacer's Avatar
FuzzRacer
Default RE: FPR...?
check for engraving on the piece, kinda like the egr systems labeling off the vack line with the arrow and the other line, or just an idea but, try to do a web search on that product or a similar FPR check out summit or some places like that, others should show you which way what goes good luck !!
Old Oct 18, 2006 | 02:15 PM
racerx55's Avatar
racerx55
Default RE: FPR...?
the bottom is the inlet, side is the outlet
Old Oct 18, 2006 | 02:30 PM
das2123's Avatar
das2123
Default RE: FPR...?
Can you take some pics of the actual regulator abd post them?
The inlet should be on the side, and you have to get the fitting. The bottom would be for your return line and the top port is for your vacuum line.
Old Oct 18, 2006 | 10:22 PM
Ice_Man_67's Avatar
Ice_Man_67
Default RE: FPR...?
I don't know if it will even work properly........how is it goin to control the pressure if it has no control over the pump/regulator in the tank?
Old Oct 18, 2006 | 11:01 PM
spudsterier
Default RE: FPR...?
in order for it to work like you would need it to you will have to get an external fuel pump.....otherwise the regulator isnt gonna serve any purpose because of the stock regulator on the stock pump
