Old Oct 21, 2006 | 08:27 PM
ohioguru's Avatar
ohioguru
Default ?
i have seen a bunch of stuff that they tell u will clean ur engine, but does any of it work?
Old Oct 22, 2006 | 02:07 AM
das2123's Avatar
das2123
Default RE: ?
Here is what I use...
ShaneHale
Everyone has their own way of cleaning the motor.
Depending on the condition it begins at:
1) Pressure wash
2a) Simple Green
2b) Rinse
2c) Wipe Dry
3) Armour All Rubber & Plastics
4) Polishing with Mother Alumn. Polish on Polished / smooth metal parts.
I will use Q-Tips to get dirt out of difficult cracks and angles. Small wire wheel to remove any RTV that may be exposed and to breath life in to the meal of the head.
Old Oct 22, 2006 | 04:25 AM
pimpberetta's Avatar
pimpberetta
Default RE: ?
If you meant cleaning the inside of the engine, use SeaFoam. Amazing stuff.
Goes in the gas and oil, cures alot of things from hesitation, to leaky injectors, pinging, knocking.
It cured my mad ticking from when my engine ran dry.
Old Oct 22, 2006 | 03:07 PM
ohioguru's Avatar
ohioguru
Default RE: ?
where would u find this sea foam?
Old Oct 22, 2006 | 04:20 PM
slow_hemi's Avatar
slow_hemi
Default RE: ?
you can find it at any autoparts store or even at walmart... works for lots of cars but have never tried it on a neon
Old Oct 22, 2006 | 04:35 PM
spudsterier's Avatar
spudsterier
Default RE: ?
i used it on my old mercedes and didnt notice a difference[:@]
Old Oct 22, 2006 | 04:43 PM
NEONRT98's Avatar
NEONRT98
Default RE: ?
ORIGINAL: spudsterier
Unless your old mercedes was a 4 cylider, I wouldnt doubt it. It clearly says on the bottle to use it in small 2 and 4 cycle engines.
Old Oct 22, 2006 | 05:23 PM
spudsterier
Default RE: ?
you can use it on 6cyl. and 8cyl. engines too
Old Oct 22, 2006 | 06:26 PM
FyreDaug's Avatar
FyreDaug
Default RE: ?
You can use it on anything, the bigger the engine the more you need. I think the dodge cc cleaner stuff is basically the same stuff. Because you run it through the engine and then let it sit
Old Oct 22, 2006 | 07:59 PM
rrwertz's Avatar
rrwertz
Default RE: ?
mopar cc is better imo. I've used both. the mopar stuff cleans more of the carbon deposits.
if you use the mopar though, you need to replace the plugs after.
