SOHC to DOHC Question
Old Oct 26, 2006 | 01:02 AM
xlogix's Avatar
xlogix
Default SOHC to DOHC Question
I know people who have swapped heads on cars like hondas and toys to change the cams but can i do this on the SOHC? I want to know if i can swap out the head from a DOHC to my SOHC to make it DOHC??
Old Oct 26, 2006 | 01:20 AM
das2123's Avatar
das2123
Default RE: SOHC to DOHC Question
Yes you can. HERE is a link to what you will need. You will need this stuff along with all new gaskets and new head bolts.
ORIGINAL: spudsterier
intake manifold
exhaust manifold
timing belt
thermostat housing(if the manifold doesnt come with it)
passenger motor mount bracket
timing belt cover(front and rear)
cam sensor
pistons/rods
should be it...unless you dont wanna modify the hood...then you need one of them too
Old Oct 26, 2006 | 01:38 AM
95neonriceeater's Avatar
95neonriceeater
how much do you think all of thoughs thing will run for?
i think i might do that...
Old Oct 26, 2006 | 01:40 AM
95neonriceeater
oh 1 more thing
in the link you posted
when you were talking about port and polishing hte intake mani
you meant port and polishing hte DOHC manifold with the swap?
and what are advantages/disadvantages with staying with the SOHC pistons?
Old Oct 26, 2006 | 09:57 AM
spudsterier's Avatar
spudsterier
lower compression....i would swap the dohc pistons too
Old Oct 26, 2006 | 12:33 PM
das2123's Avatar
das2123
ORIGINAL: 95neonriceeater
oh 1 more thing
No, it just had more info about swapping to a DOHC head in it.
Old Oct 26, 2006 | 04:42 PM
95neonriceeater
alright
how much would htis all cost?
Old Oct 26, 2006 | 06:59 PM
spudsterier
depends on where you get it from
Old Oct 26, 2006 | 07:43 PM
NEONRT98's Avatar
NEONRT98
Dude, do some research :-D You can learn alot by doing it
Old Oct 26, 2006 | 07:51 PM
NEONRT98's Avatar
NEONRT98
Also, dont forget you need to swap out the PCM too...
