couple minor porblems now....
Old Nov 4, 2006 | 03:31 AM
Youngstown97Sohc's Avatar
Youngstown97Sohc
From: Youngstown , ohio (muder capital per capita u.s. )
Default couple minor porblems now....
well ... now that my baby is running better , im looking at a few minor tweaks i have...
first , when im driving , and i brake , i get wobble in the left side..almost like a tie rod.. anyone have any previous experience with a broken belt , and what that feels like...
next problem associated with said previous problem , is if i get a good wobble , my left turn signal kinda trips to the "almost , but not quite" on position.. it kinda just stays on... a light touch of the combination lever fixes this , but this is annoying seeing as im looking at putting 2 10's in my backseat... lots of bump...
my next question is , rims.. who makes some nice cheapo rims that could handle day to dya driving... no major turns or pressure , but nothin too cheap...
im outta ideas already , but there will be more..
hova
Old Nov 4, 2006 | 03:36 AM
HabitatHxC's Avatar
HabitatHxC
Default RE: couple minor porblems now....
I know about the turnsignal... i have a similar prollum! When i tap the break pedal really fast it kicks on and off on and off. Is it the left?
Ive see a post about it on here, And apparently its a common problem! I just deal with it, so i dont know how to fix it.
Old Nov 4, 2006 | 04:01 AM
winsettz's Avatar
winsettz
I thought wobble was un-even wear of brake pads?
Old Nov 4, 2006 | 04:18 AM
iwalton63's Avatar
iwalton63
I had the same problem with mine. It was because one of the springs on the inside was broken. You will most likley have to replace the mutli switch( its the whole balck thing, the turn signal lever and the hazards lights.) its farley cheap.and very easy to change.
Old Nov 6, 2006 | 05:33 AM
Youngstown97Sohc
yeah it turns on to the left... i figured one of the combination switches was bad , and i havent messed with it yet b/c my air bag light is on all the time... i sit waaaay back just to be safe...lol
but yeah , i kinda just deal with it..its only happened a few times and its not like the other things im watching for when driving... one of these days im waiting to see a rod blow thru the hood (my honda did said action , throwing a rod through my hood @ 5000rpm ....oh well) ....
i figure worst case scenario im just going to the junkyard tomorrow for some stoopid misc parts , and may pull a combi switch ...
any info on switching to a combi switch with cruise control or any upgrades ? they all plug in the same no matter what model right ?? (i mean the same year , etc , but highline ,yadda yadda all have the same plug...just more wires...???)
thanks guys
hova
Old Nov 6, 2006 | 09:47 AM
spudsterier's Avatar
spudsterier
yeah its all the same plug......
i think its alomst impossible to throw a rod through the hood on a neon.....so there is one less thing to worry about, however, out the oil pan is a different story
for the wobble i would get new rotors or get the old ones turned
Old Nov 8, 2006 | 04:17 AM
Youngstown97Sohc
my brakes seem to be fine... im not getting any niose from them at all , and theres no noticeable gouges...
when i take my car in tomorrow , im going to see if i can have them reseal , and balance all 4 tires... most places around here dont use grease to seal tires , and it really is necesary...
hova
Old Nov 8, 2006 | 04:31 AM
jared6180's Avatar
jared6180
Tires is where i would start on the wobble, but from there move into the brakes as it could be uneven pad wear or a warped rotor!!!
Old Nov 8, 2006 | 04:33 AM
Youngstown97Sohc
warped rotor...i forgot about that.... thats very possible....
thanks
hova
