compression gauge necessary......
Old Nov 14, 2006 | 10:59 PM
press1280's Avatar
press1280
Default compression gauge necessary......
for TDC placement? It seems like it isn't although Haynes says it is. Also, I've got a ton of oil on my alternator,splash shield,everywhere in that general area. It seems its the cam seal,right? So I guess I'll be doing the t-belt,water pump also. I guess I need the t-belt and what else(tensioner pulley kit)? Advance auto parts sells the t-belt by itself only. Any particular brands to avoid or get?
Old Nov 14, 2006 | 11:13 PM
tomthedog's Avatar
tomthedog
Default RE: compression gauge necessary......
to find TDC you can use a long screwdriver with the plug removed. watch close and you will notice the screwdriver stops moving at the highest point while the crank still moves. find the mid-piont of this area, you will be at TDC or 180 out. if your chaning the t-belt you will find the mark for TDC. i'd change the valve cover/sparkplug tube gasket set as well. make sure the filter is on tight too. good luck.
Old Nov 14, 2006 | 11:49 PM
spudsterier's Avatar
spudsterier
ORIGINAL: tomthedog
you forgot a necessary step....you need to put the screwdriver down in the sparkplug hole so that the end sits on the piston
i use a wooden dowl rod or a steel rod
Old Nov 15, 2006 | 09:28 PM
press1280's Avatar
press1280
OK,got that part. Should I spend more $$ on a lifetime warranty timing belt?
Old Nov 15, 2006 | 11:10 PM
winsettz's Avatar
winsettz
A lifetime warranty just means the belt will last you a hundred kay miles, whoop de do if you have a bad brand that actually breaks and they give you a new belt, leaving you the cost of new engine parts when the belt breaks.
Which brand of belt were you considering?
Old Nov 15, 2006 | 11:57 PM
spudsterier
get a gatorback
i hve a gates on my car....cant tell you if its any good since the car isnt running yet
Old Nov 16, 2006 | 09:22 PM
press1280's Avatar
press1280
There's Goodyear for 30$, Drive Rite for a few more and Beck/Arnley topping out at 75$. Also Dayco for 36$ for the cam belt tensioner pulley(I guess I'll need this too)?
Old Nov 17, 2006 | 01:16 AM
spudsterier
if your gonna change the belt then change the idler pulleys too
