need some major help
Old Nov 15, 2006 | 02:45 AM
cjparker12345's Avatar
cjparker12345
Default need some major help
I think my linkage or something in my transmission if screwed up because drivin down the road the other dayi went to go into second from third and the lil button wouldn't push in and then it started stickin. so i made it home in second , got turned around in the driveway and then it got stuck in third and i finally coaxed it to go into neutral and now i have it in park but i can't get it to slide past reverse. Anyone have this problem or could tell me what has happened and how to fix it?
Old Nov 15, 2006 | 02:57 AM
winsettz's Avatar
winsettz
Default RE: need some major help
Could be the cable that connects the shifter to the transmission, or something more ominous...
Old Nov 15, 2006 | 03:00 AM
cjparker12345
kk it seems like it jammed or something because it is extremely stiff
Old Nov 15, 2006 | 03:06 AM
winsettz's Avatar
winsettz
Wonder if it's the interlock system...
Old Nov 15, 2006 | 03:13 AM
cjparker12345
hey whats that?
could it really be the problem im hopin its nothing serious
how do i check
Old Nov 15, 2006 | 03:19 AM
winsettz's Avatar
winsettz
Interlock locks the shifter into park when the key is set to lock or Acc. Maybe it's not disengaging, but it's probably more likely to be a shifter cable issue? Though a busted shifter cable might be more like shifting through everything easily but never leaving park. Which leaves you with transmission-related things.
Edit: Might as well start with the obvious. Fluid levels, fluid condition sort of thing. Leaks to crankcase?
When you say going from 2nd to third it sounds like MTX but you mention a "little button" which makes it sound more like ATX. When you say 2 to third I take it you mean 2 to D?
Old Nov 15, 2006 | 03:32 AM
cjparker12345
it is and automatic and D is the third and final gear... whats confusing about that
Old Nov 15, 2006 | 03:33 AM
cjparker12345
so with a manual swap what fab will it take to get the clutch pedal and shifter in there?
Old Nov 15, 2006 | 09:50 AM
spudsterier's Avatar
spudsterier
no fabrication needed....just remove the old and bolt in the new....
ok, so you were downshifting in the auto and it messed up???? do you manually shift the gears alot???? if you do then thats probally what the cause of the problem is....you might of just messed up the tranny, autos are ment to automatically change gears, not always manually
Old Nov 15, 2006 | 01:19 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
I agree with this statement. You shouldn't manually shift an automatic, bad idea and problems to follow.
