New to neons, stumped on cyl1 misfire, HAVE searched
Old Nov 19, 2006 | 01:30 AM
  #21
ewetho's Avatar
ewetho
Default RE: New to neons, stumped on cyl1 misfire, HAVE searched
PCM sets a misfire code by watching the crank sensor velocity and notes the slow down when Cylinder #1 for instance should be firing.
Fuel pressure while driving would be a good indication.
As far as fuel trim, it is normally in % -taking fuel away +adding fuel. Easy. Should be 0 ±5. If you are ±10 or more than you have an issue. If you are adding lots of fuel and lean than either fuel pressure is low or you have a localized air leak.
19-20 lbs. of vacuum sounds good.
I would really suggest a leak-down compression test.
If you have access to a scope or at least duty cycle on a DMM then check the #1 fuel injector signal vs another. (multiple noid lights a potential possibility too)
For odds and ends.......
Check you MAP sensor for contamination &
Double check you belts and pulleys just to be safe.
Old Nov 19, 2006 | 04:51 AM
  #22
index420's Avatar
index420
Thanks for info...especially about the fuel trim..tells me my eclipse is running way off lol...but anyway havent had much time to spend with the neon, but I plan to do all these things when I get a chance...possibly tomorrow....not sure what duty cycle on a DMM means though?? Ive got a multimeter if thats what you mean...and it is digital... but I do believe i can manage the noid lights..
-why cant I get this much help on dsmtuners.com?! anyway thanks again!
