Turbo SOHC
Old Nov 20, 2006 | 03:25 AM
burntricer's Avatar
burntricer
Default Turbo SOHC
plz dont flame, i searched.
car - 95 SOHC ATX
Goals - 200 hp (to match my cavalier)
Budget - 2k
Plans
Garrett T25 Turbo (havent decided on the trim tho, probably gunna just use an SRT4 turbo)
Custom Manifold
HUGE FMIC
Walbro F/P
Cartech FMU
Bigger injectors (if necessary, hence why im asking)
PSI, not much more then 7-10
Autometer TruBoost gauge/bc
Turbo XS BOV
What else do you recommend?
ive designed and built a few of these kits (cavaliers/sunbirds/ CRX), so im no NEWB for turbos'
curious, what other f/i ppl are running for fueling, ECM, boost controllers ect
Old Nov 20, 2006 | 04:17 AM
ZiggyNeon's Avatar
ZiggyNeon
Default RE: Turbo SOHC
there is a sticky up top with an srt 4 turbo checklist in it
also search for spuds turbo w.i.p with pics post
Old Nov 20, 2006 | 09:26 AM
FastNeon84's Avatar
FastNeon84
if you are going to run 7-10 psi on a stock bottom end, make sure it gets tuned properly so you wont throw a rod or blow piston rings. You may be well over 200whp though...my guess, probably in the 240-270 range. $2000 is a not a bad budget for what you're trying to do, depending on where you get all of your stuff at. check out ebay... and type in " neon turbo kit." there are a few good kits on there selling for 1000-1500. you might spend a few extra hundred dollars upgrading the fuel system though (ex. fuel rail, injectors, fuel pump, fuel pressure regulator).
Old Nov 20, 2006 | 11:13 AM
spudsterier's Avatar
spudsterier
make sure to get the walbro external fuel pump.....
no larger the 2.5" intercooler piping
you also need a mapclamp
you need to add a retun line....and return line to the pump
you dont need the bigger injectors unless you are wanting more power then what you said
you might wanna pick up an AGP wastegate too....
$2,000 isnt bad for a turbo kit depending on what way you want to go.....the srt kit for me has come to about 1500
Old Nov 20, 2006 | 05:51 PM
burntricer's Avatar
burntricer
i was looking at the SRT4 turbo, and it is built to the manifold, but is DOHC no?
Old Nov 20, 2006 | 08:51 PM
das2123's Avatar
das2123
ORIGINAL: burntricer
You would need an adapter plate that costs about $220 shipped to get the SRT-4 turbo/manifols to bolt up to the SOHC head.
Old Nov 20, 2006 | 11:51 PM
spudsterier
still cheaper for everything and the plate then a hahn turbo kit
Old Nov 21, 2006 | 06:27 AM
95neonriceeater's Avatar
95neonriceeater
arent the sohc pistons better if we put the turbo on our engine?
Old Nov 21, 2006 | 10:27 AM
spudsterier
just for a little lower compression
otherwise the pistons are built the same
Old Nov 21, 2006 | 01:10 PM
das2123's Avatar
das2123
ORIGINAL: 95neonriceeater
Technically yes since they lower compression a bit.
