i got a question
Old 11-26-2006, 02:39 PM
mixedbeetz's Avatar
mixedbeetz
mixedbeetz is offline
Default i got a question
i just got a 95 neon sport dohc 2.0 and i was woundering what are the gains of blocking off an egr valve?
second would having a hallowed out cat make my comp light go on and say its my o2 sensor not ablr to switch back and forth and i also have a code on my egr saying its not working what should i do any help would b appreciated
Old 11-26-2006, 07:29 PM
das2123's Avatar
das2123
das2123 is offline
Default RE: i got a question
There are no performance gains to bloccking off your EGR valve. For the code, you can pull the EGR valve off and cleaning it up. Most of the time the transducer is what goes bad though.
Old 11-26-2006, 07:53 PM
jared6180's Avatar
jared6180
jared6180 is offline
if you hollow out your cat you will start throwing codes, they sell an eliminator for it or I think you can tune that code off.
Old 11-26-2006, 10:41 PM
daveyg's Avatar
daveyg
daveyg is offline
ORIGINAL: jared6180
It's easier to just get a few extra 02 "bung" nuts that will thread onto the O2 sensor, and then you can hollow out the cat and just space the O2 sensor about 1/2-3/4" away from the pipe (by welding a few nuts together, and welding them to the original O2 bung) and it will slow down the amount of exhaust passing by the sensor, making it read as though it had the restriction of a cat, which slows the exhaust.
Old 11-27-2006, 04:22 AM
jared6180's Avatar
jared6180
I had a stainless catless pipe on a previous neon and there is very little performance gain, not even worth it, all it does is make the car TOO noisey!
Old 11-27-2006, 10:04 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
i loved the gutted cat on my car.....i just cut mine out and put a piece of straight pipe in there....then welded the new bungs to it and never had a problem with the check engine light.....
Old 11-28-2006, 04:21 PM
neoncrazy101's Avatar
neoncrazy101
neoncrazy101 is offline
what are u guys talking about with the bungs? what are they?
Old 11-28-2006, 11:44 PM
mixedbeetz's Avatar
mixedbeetz
i like to thank yall for your help i am just going to get a cat back on and change the o2 sensors and the egr valve and hopefully it will solve the problem. i also have a problem with water getting in and i dont know where its coming from its all on pass side both the floor in the front and rear are always wet its even wet now and it hasnt been in any rain for a while i dont know any helpl will b appriciated
Old 11-29-2006, 11:29 AM
das2123's Avatar
das2123
das2123 is offline
Your taillight gaskets may be leaking, letting the water in. Have you checked your truck in the spare tire area??
Old 11-29-2006, 11:34 AM
FastNeon84's Avatar
FastNeon84
FastNeon84 is offline
drill small holes in the taillights to get the condensation and the water will eventually come out.
Quick Reply: i got a question
