no start
Old Nov 30, 2006 | 12:08 PM
speedytoy's Avatar
speedytoy
Default no start
My sons 98 neon did not want to start after he came home from work. I looked at it but
I am not sure whats wrong with it, when you turn the key forward you get nothing but
the lights, radio, fuel pump everything works. I cleaned the battery posts and also
tried jumping it but still nothing. If there is any suggestions on what to do next it would be helpful.
Old Nov 30, 2006 | 12:25 PM
mike9fore's Avatar
mike9fore
Default RE: no start
Did you check your plugs? or it could be a faulty starter....
Hope this helps
Old Nov 30, 2006 | 12:59 PM
speedytoy's Avatar
speedytoy
I will have to check the starter tonight, I don't think it's the plugs.
The motor will not even crank over.
Thanks
Old Nov 30, 2006 | 01:07 PM
mike9fore's Avatar
mike9fore
Starter.....
Old Nov 30, 2006 | 01:44 PM
hnda8r's Avatar
hnda8r
I will have to say starter as well
Old Nov 30, 2006 | 01:53 PM
das2123's Avatar
das2123
I'd check your fuses and relays first before changing the starter.
Old Nov 30, 2006 | 02:24 PM
Only Another's Avatar
Only Another
That happened to mine a while back ago but after i pulled the starter out, tested it only to find it working perfectly, i touched a screwdriver on one of the terminals and it gave me enough amps...but if you already cleaned the terminals and messed with it, then go w/ the starter
Old Nov 30, 2006 | 03:15 PM
speedytoy's Avatar
speedytoy
Thanks for the input, I will take the starter out and have it tested, I will aslo try the relays switch.
Old Nov 30, 2006 | 03:20 PM
das2123's Avatar
das2123
ORIGINAL: speedytoy
Do this first
