tachometer problems please help
Old 12-11-2006, 01:33 AM
civiceater88's Avatar
civiceater88
civiceater88 is offline
Default RE: tachometer problems please help
ohhhhh ok cool...how would i hook it ^???same way as it is from the pcm
Old 12-11-2006, 01:48 AM
das2123's Avatar
das2123
das2123 is offline
Just splice it in.
Old 12-11-2006, 01:49 AM
civiceater88
and the stock one has to disconnected rite?
Old 12-11-2006, 01:52 AM
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: civiceater88
If you cut the wire that connects to the cluster, then it is disconnected.
Old 12-11-2006, 01:55 AM
civiceater88
so cut it rite be4 it connects to the connecter with all the other wires?
Old 12-11-2006, 02:05 AM
das2123's Avatar
das2123
das2123 is offline
Yes...although it should already be cut. I thought you said you disconnected the stock tach?
Old 12-11-2006, 02:09 AM
civiceater88
yeah i did....rite behind the pcm.....but i would have to hook the stock back ^ and cut it along the cluster and splice it behind the stock guages
Quick Reply: tachometer problems please help
