tachometer problems please help
Old 12-10-2006, 04:06 PM
civiceater88's Avatar
civiceater88
civiceater88 is offline
Default tachometer problems please help
ok soo i boguht a jdm sport tachometer.....every thing works but the tach part....after figureing out the stock tach must be disconnected i did that and the after market tach stil doesnt work....does anybody know how to help
Old 12-10-2006, 07:38 PM
das2123's Avatar
das2123
das2123 is offline
Default RE: tachometer problems please help
Did you cut the stock tach wire?
Old 12-10-2006, 09:10 PM
civiceater88
yes i did and it still doesnt work
Old 12-10-2006, 09:28 PM
das2123's Avatar
das2123
das2123 is offline
How did you hook it up?
Old 12-10-2006, 09:33 PM
civiceater88
i have the power running off the igniton switch the light is spliced into the light switch and the tach is hooked ^ to the stock tach wire coming off ther pcm everytihng works but the tach part of it
Old 12-10-2006, 11:33 PM
das2123's Avatar
das2123
das2123 is offline
Try running the tach signal wire from behind the cluster. What year is your car?
Old 12-11-2006, 12:12 AM
civiceater88
its a 96 expresso model....where in the back of the cluster would i hook it ^ at????????
Old 12-11-2006, 12:17 AM
das2123's Avatar
das2123
das2123 is offline
Tachometer signal wire...its gray with a light blue tracer.
Old 12-11-2006, 12:21 AM
civiceater88
well rite now i have it hooked up to the gray wire with the blue tacer rite off the pcm will it make a differecne if its hooked ^ behind the dash
Old 12-11-2006, 01:14 AM
das2123's Avatar
das2123
das2123 is offline
I have heard some people with your similiar problems and then hooked it up behind the dash and it works.
Quick Reply: tachometer problems please help
