idles up
Old Dec 23, 2006 | 04:14 PM
mcoyle05's Avatar
mcoyle05
Default idles up
i have a dodge neon that idles up when i bearlytap the pedal. the rpm will rise to about 2200-2500 and very very slowly return to regular rpm... i made the mistake of resetting the computer via power loss before running a ObdII diagnostic so no code is showing. if anyone can help me it would be greatly appreciated.
Old Dec 23, 2006 | 04:30 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: idles up
when your just at idle is the RPMs +/- 200 RPMs? aka idle is roughly 900rpms so it would be around either 700RPMs or 1100RPMs... cause it sounds like a vacuum leak
Old Dec 23, 2006 | 04:36 PM
mcoyle05's Avatar
mcoyle05
yea it sits at 1100... im going to check over the vaccum system today... already tried replacing the TPS... obviously wasnt it
Old Dec 23, 2006 | 09:18 PM
neoncrazy101
yea i would check all your vacuum hoses...but if that doesn't fix it then and if your brakes dont work...like they work but not as well as they used to (aka no more power brakes) then i would replace the brake booster. on our Neon we had to do that and it fixed the idle problem.
Old Dec 24, 2006 | 12:13 AM
das2123's Avatar
das2123
Might wanna pull the throttle body off and clean it up real good also.
Old Dec 24, 2006 | 08:32 AM
HabitatHxC's Avatar
HabitatHxC
Mine does this as well, it has done it Since i have had it, replaced headgasket all gaskets around it all hoses, new tps, cleaned up the Throttlebody, Everything, and it still does what your saying it does, "bearly tap the gas the RPMs go up and come back down slowly" But with my exhaust it kinda rumbles as its going down and sounds mean so its all goood =D I find it fun! I have no other problems with it (knock on wood) Ill make a video of it in the mornand we'll see if its the same thing.So hopefully it isnt a big problem, I personally dont think it is!
Old Dec 24, 2006 | 11:45 PM
JDC420's Avatar
JDC420
My 96 sohc does the same thing SOMEtimes. I was thinking TPS, but I guess that might not be it!
Old Dec 25, 2006 | 01:39 AM
mcoyle05's Avatar
mcoyle05
i checked all the vaccume hoses and no results... anyone have any other ideas?
Old Dec 25, 2006 | 01:47 AM
neoncrazy101
hmmm could just be a happy Neon lol
Old Dec 26, 2006 | 05:33 AM
DNeon's Avatar
DNeon
mine idles at 1100 RPM too...I have no problems wit it. I thought that was the idle range lol it doesnt do the whole revvin high when I tap it tho...an even when I'm at 3000 RPM an push in my clutch it quickly goes down to 1100.
