Upgrade/Replacement Shifter
Old Jan 19, 2007 | 12:30 PM
michakaveli's Avatar
michakaveli
Default Upgrade/Replacement Shifter
The shifter assembly on my '95 5-speed has some play in it. I took a peek in there and part of the problem lies with what appears to connection of the main shift rod (prolly going to the tranny) and the rest of the assembly. It appears as if there should be a C-clip of sorts securing it on w/ a washer, but obviously none there. Also a short shifter would be nice as the shifts just seem to take too much time rowing through gears... I looked on eBay and there was what seems a complete shift assembly for the Gen II Neon, but none for the Gen I.... Where else can I look?
Advise ya'll!
Old Jan 19, 2007 | 02:08 PM
tranyinstaller's Avatar
tranyinstaller
Default RE: Upgrade/Replacement Shifter
for the enthusiast many companys do make them including for the first gen. neon but get ready to get out ur wallet! u can go to andy'sautosport.com but if ur broke like the rest of us i suggest other wise. go to a junkyard and get a repalement stock, then get out the good old sawz all and cut the shifter short. if u want or need i can fabricat a custom shifter for u out of aluminum. this is what i did in my neon and it works great when i get the chance i'll send pix.
Old Jan 19, 2007 | 04:51 PM
michakaveli
ORIGINAL: tranyinstaller
If you can send some pix that's fine. If I can just cut it down some that's prolly all I would need. Actually I remember a friend some time ago cut his shifter down some on his Civic and it worked out great. I assume to remove the shift **** and boot I need to turn the **** to the left or just pull up? If you could post pix here and send an email with photos to michakaveli@gmail.com I'd appreciate it....
Old Jan 20, 2007 | 12:45 PM
das2123's Avatar
das2123
Get some booger bushings for $20 to get rid of the play n your shifter. They are definitely worth the money. I have a cut shifter on my 97 parts car if you are interested in it.
Old Jan 20, 2007 | 01:47 PM
michakaveli
ORIGINAL: das2123
Ordered the bushings, I'll keep posted on the result(s) once installed
Old Jan 20, 2007 | 02:28 PM
das2123's Avatar
das2123
ORIGINAL: michakaveli
ORIGINAL: das2123
You won't be disappointed...what color did you get?
Old Jan 20, 2007 | 04:44 PM
michakaveli
yellow so they're easily visible :-)
Old Jan 21, 2007 | 12:53 AM
spudsterier's Avatar
spudsterier
to remove the **** you have to pull the boot down a bit....there are 2 clips, one on each side or the handle.....pry out on the clips and pull the **** straight off......
to remove the boot, you have to remove the center console......from there, there are 2 but-plugs on the back and 1 on the front under the boot.....once the console is out, you can see the plugs from the side of the handle
Old Jan 21, 2007 | 08:43 AM
HabitatHxC's Avatar
HabitatHxC
Or you could go with the SRT4 Shortthrow, with a little work,
Old Jan 22, 2007 | 01:48 AM
michakaveli
ORIGINAL: HabitatHxC
elaborate please...
