oil pressure sensor
Old Jan 25, 2007 | 04:45 PM
dcmcguy's Avatar
dcmcguy
Default oil pressure sensor
where is the oil pressure sensor on a sohc?
Old Jan 25, 2007 | 05:00 PM
das2123's Avatar
das2123
Default RE: oil pressure sensor
On the back of the block about midway down.
[IMG]local://upfiles/33897/4656BCD47E7B43FBB99256CCB5B17E54.jpg[/IMG]
Old Jan 25, 2007 | 07:09 PM
romeo21's Avatar
romeo21
can you put an apc oil presser gauge on that sencer and witch wire do you tap in to and how do i do an air to fuel gauge every one tells me its the grey wire on the o2 sencer butwhen i did that it show all the bars
Old Jan 25, 2007 | 07:27 PM
das2123's Avatar
das2123
It's better to replace the sender with an aftermarket one.
Old Jan 25, 2007 | 07:44 PM
romeo21's Avatar
romeo21
the kit that i got comes with a aftermacket sencer but if i remove the stock sencer will my oil light come on and can i send you some pictures of what i got
Old Jan 25, 2007 | 07:53 PM
spudsterier's Avatar
spudsterier
the oil light wont come on when the sender is remover becuase it ground out on the block......no ground, no light.....
i made the T fitting i have so that i could put my oil feed line in one outlet, and the autometer oil sending unit in the other...then it just screws into the stock loaction on the block.....
chances are you will have to get a simlar adapter for the aftermarket sender....since the thread pattern should be different then the stock one
Old Jan 25, 2007 | 08:00 PM
romeo21's Avatar
romeo21
hey spud check our yahoo .mail ill send you some pictures of what i got
Old Jan 25, 2007 | 08:15 PM
das2123's Avatar
das2123
Some aftermarket oil senders do fit right in with no problems.
Old Jan 25, 2007 | 11:23 PM
spudsterier
i am sure some do...just not the autometer is all i was saying
Old Jan 26, 2007 | 12:55 AM
romeo21's Avatar
romeo21
hey das were is the oil presser sencer at
