oil everywhere
Old Jan 26, 2007 | 01:43 PM
spudsterier's Avatar
spudsterier
Default oil everywhere
ok so, when i really beat on my car a little....or alot.....oil spits out my little breather filter on the drivers side.....the filter is saturated and 1 time, oil was all over the turbo and valve cover and hood..the car was smoking so bad i thought it was on fire[&:]
so, i was looking into making an oil catch can...but noticed that it mounts between the pcv valve on the passenger side and the throttle body...
so, my question is:
can i just block off the valve that the breather is on??? or will that hurt it at all????
i would assume if the oil shoots out like it does from the little breather, then it also goes through the pcv valve....so i know i should put a catch can in there...but im just lost with the breather[:@]
Old Jan 26, 2007 | 02:38 PM
das2123's Avatar
das2123
Default RE: oil everywhere
ORIGINAL: spudsterier
Leave it on or get the tube that connects to the air intake tube and install the catch can.
Old Jan 26, 2007 | 03:11 PM
fullbuilt's Avatar
fullbuilt
ya gotta have it breath or youll build up too much pressure and crack your head or cover
Old Jan 26, 2007 | 08:58 PM
Dazzellerr's Avatar
Dazzellerr
luckily, 95 neons have a oem catch can lol.
Old Jan 26, 2007 | 10:21 PM
spudsterier
yeah i found out all i needed to know from the srt section......
i am gonna get 2 of them and put one on each......
im gonna use the air/water separators from an aircompressor...im picking them up tomorrow and gonna install them hopefully tomorrow nite
Old Jan 26, 2007 | 11:34 PM
FastNeon84's Avatar
FastNeon84
so, my question is:
so does this happen when you turbo all neons? i need a catch can too?
Old Jan 27, 2007 | 12:40 PM
das2123's Avatar
das2123
ORIGINAL: FastNeon84
It's a good idea to have one.
Old Jan 27, 2007 | 12:55 PM
Whatsrt4's Avatar
Whatsrt4
so, my question is:
Just to be safe you might want to check your oil sending unit, mine was leaking where the oil line went out to the turbo.It made a lot of smoke!!. Oil catch can is a good idea also.
