Why is this car sqeaking??
Old Jan 27, 2007 | 05:46 PM
jewells3404's Avatar
jewells3404
Default Why is this car sqeaking??
Ok soI have a 98 neonwhenever I turn my front or rear defrosters on my car squeels like crazy and when i turn it off then its fine what is wrong with this thing??? I've had so many problems with this car I can't wait till I get a new one in spring
Old Jan 27, 2007 | 07:02 PM
fullbuilt's Avatar
fullbuilt
Default RE: Why is this car sqeaking??
the heater motor is goin bad
Old Jan 27, 2007 | 08:10 PM
Beauff's Avatar
Beauff
Need to tightin your alternator belt.
Old Jan 27, 2007 | 10:44 PM
fullbuilt's Avatar
fullbuilt
ORIGINAL: Beauff
what??
Old Jan 27, 2007 | 10:48 PM
HabitatHxC's Avatar
HabitatHxC
Tighten your alternator belt, it is loose.
Old Jan 28, 2007 | 09:30 PM
jewells3404
is it expensive to get done? cuz I have a lot of other work going to the car i might just get rid of it
Old Jan 28, 2007 | 09:40 PM
fullbuilt's Avatar
fullbuilt
i dont know how the heater would affect your alt belt but tightning it up is easy is a 15mm wrench on the side to loosenand a 13 on the rear to tighten then tighten the 15
Old Jan 29, 2007 | 12:35 AM
spudsterier's Avatar
spudsterier
ORIGINAL: fullbuilt
there is actually a 15mm swivel bolt on theside at the bottomthat you can get to through the wheel well....
then you have the 15mm bolt lock bolt on the side at the top.....
then there is the 13mm bolt on the back that actually moves the alternator to tighten/loosen
the rear defroster takes a good deal of power to have on....when you turn on the defroster, the alt. belt will sumtimes squeel from haveing to work a little more....
mine does it when i turn the heat on....then when i turn it off, or get the rpm's up a little, it goes away
Old Feb 1, 2007 | 02:37 AM
pimpberetta's Avatar
pimpberetta
Yeah, when you turn on that defroster it builds up resistance in that alternator and loads the motor down making it harder to turn the alt. so it slips.
Tighten the belt, see what happens, if not, time for a new belt then.
Old Feb 1, 2007 | 05:03 AM
johnneon's Avatar
johnneon
that 1 was good the heater motor is going bad,,,,,fullbuilt made a funny,,,,,what does the rear defrost have to do with the heater motoritsalt belt it also does that when its really cold,,,i hear that alot,,,on my chevy [:'(][sm=TY.gif]the sound of a belt slipping just makes u wanna pull ur hair out,,,
