door panels
Old Feb 1, 2007 | 07:31 PM
romeo21's Avatar
romeo21
Default door panels
are there any door panels that have power doors and power windows that will fit a two door i dont think that there is any thing with power windows for a 96 neon
Old Feb 1, 2007 | 07:39 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: door panels
do you mean power lock and windows?
Old Feb 1, 2007 | 07:58 PM
romeo21's Avatar
romeo21
yeah but is there a panel for a two door that has both or at lest power locks i heard thar the r/t has power locks in the two door
Old Feb 1, 2007 | 08:14 PM
romeo21's Avatar
romeo21
see im looking for some thing like this somthing that has power locks and power window or am i going to have to look for some aftermarkit
Old Feb 1, 2007 | 08:31 PM
spudsterier's Avatar
spudsterier
there are alot of 2 door neons that have that combo.....any year from 95-99 will work
alot of r/t's do have them...but mine didnt....though my last 2 did.....
i dont have any good ones...the only 2 i will have are blue and have the speaker holes cut out.....
check junk yards or maybe ebay........as long as you can find some with the power locks or mirrors, you can cut out the opening for power windows like i did
Old Feb 1, 2007 | 08:42 PM
romeo21's Avatar
romeo21
ok now if i do find the doors isit esayer to just change out the hole door or is it just the same to change the components and how would i wire it i have noticed that in the fuse panel i have the slot for power doors and window do i just plug the wires in the back and put a fuse
Old Feb 1, 2007 | 08:54 PM
spudsterier
open your door....find the big wire loom that goes from the door to the car....
pull off the end of the loom thats on the door......if there are a bunch of wires in there then your car is prewired for all the options.....
if you only have a couple wires, then you are gonna have a hell of a job ahead of you........
it will be pretty easy to just take the door panel, mirrors, lock mechanism, and the power window track and motor assembly.....just make sure to get the wire harness out of the door too...then you can just swap it all into your doors.....
there might be a slot for the fuse, but all the fuse boxes are basically universal......
if your car is prewired then make sure that after you install it all, remove the bottom of the dash and check out the fuse box.......there is a fuse in there for the windows...but there is also a slot for a fuse on the top of the box that you cant see when the dash is on it....i had this problem with mine...took me about an hour to realize that there was a fuse up there[&:]
Old Feb 1, 2007 | 09:10 PM
romeo21's Avatar
romeo21
ok well i just called a junk yard and they have a set its going to be 185 for both panels and the window and doorcontroles. so all i need is the motor and the harness?
Old Feb 2, 2007 | 12:22 AM
spudsterier
motor, harness, and the window tracks
Old Aug 13, 2007 | 02:59 PM
southernalabama's Avatar
southernalabama
I am looking for a driver's side door panel with door handle/lock mechanism for a four door 2003 Dodge Intrepid. Can anyone off any suggestions? Please email me at sunriseinbama@yahoo.com.
Thanks
Cindy
