1st Gen FAQ's and How-To's
Old Feb 2, 2007 | 02:33 PM
das2123's Avatar
das2123
Old Sep 12, 2011 | 07:16 PM
Logan338's Avatar
Logan338
I've ask all over, dealer, parts store, not one good answer. On the air inlet duct, where does the tube leading out of the bottom connect to. Any help given would be great! Thanks.
Old Sep 30, 2011 | 08:30 AM
scottunangst's Avatar
scottunangst
Default alternater ajusting bolt
this post was help for me adjusting my neons loose alternater belt. i have a cold air intake so the stock air box has been removed. from the drivers side the 13mm adjusting bolt is easy to get to. the air box removal is less work than moving the coolant and power steering tanks, also gives you more room. hpoe this helps, thanks, scott.
Old Jun 21, 2012 | 05:55 PM
boowayne's Avatar
boowayne
Default 95 neon
what would cause my neon to bog after installing a M2performance header it doesn't bog bad but when i hammer the throttle down it will increase speed but with a slight bog
Old Jun 22, 2012 | 06:44 AM
scottunangst
your engine is not getting enough fuel now that it is breathing better with the header. upgrading your computer(ecu) will get you more fuel and advance your timing a little.
Old Sep 11, 2012 | 05:34 PM
cskaj88's Avatar
cskaj88
I have an ATX 1998 Dodge Neon with the 2.0 SOHC. Looking to just make it run like new or slightly better it's my to work an home car. The engine I have in it as of right now has 114k Miles. Any advice?
Old Sep 24, 2012 | 01:28 PM
96dohcsportcoupe's Avatar
96dohcsportcoupe
how does it run?
Posted from Dodgeforum.com App for Android
Old Feb 26, 2013 | 01:56 AM
Kyle Richard's Avatar
Kyle Richard
Default stock flywheel weight
What is the weight of the stock flywheel in a 99 neon sport?
