bore size
Old Feb 12, 2007 | 12:47 AM
spudsterier's Avatar
spudsterier
Default bore size
anyone know what the standard bose size is of the dohc block????
and
i figure the 8.8:1 pistons would work the best, but how bad would it be to have 10.5:1
im just wondering because im thinking of ordering my bottom end stuff in a day or 2 and just need to know some opinions before i spend the money
Old Feb 12, 2007 | 01:13 AM
rtneon67's Avatar
rtneon67
Default RE: bore size
if u get the 8.8:1 i think u have to bore your block .20 over u can use the 10.5:1 but i wouldnt recommend it with a turbo
Old Feb 12, 2007 | 01:39 AM
romeo21's Avatar
romeo21
i am planing on rebuilding a motor what is the best sizeto put in but i do plan on runing a turbo but just not any time soon is this a stupid idea or would it work
Old Feb 12, 2007 | 02:09 AM
FastNeon84's Avatar
FastNeon84
the lower the compression....the better for the turbo..(spud i know u already knew that[sm=insomnia.gif]) running high comp pistons i dont think would be a good idea....
which pistons are you going with spud... weisco or je?
Old Feb 12, 2007 | 12:13 PM
fullbuilt's Avatar
fullbuilt
now i just got done last year running 10.5:1 on my turbo boosted quicker than hell and had massive mid power. i made it 3 months of beating it on the track before it blew. i was surprized it made it that long. if you dont get to crazy with the boost and watch your tune it may last you quite long you will deffinately feel a low end difference. but keep in mind i was at 22psi and 100shot nitrious and stomping on it constantly.
Old Feb 12, 2007 | 01:30 PM
spudsterier
well i would be beating the hell out of the car and i only want to run 15psi. and no nitrous.....
i just want to get the most out of this motor as i can for the money.....
i only wanna use the JE pistons
i just wanna know the main difference between running high or low compression......but i guess that i might as well just use low so i wont be rebuilding the motor again too long down the road[&:]
Old Feb 12, 2007 | 01:54 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
You said it and you are right.
Old Feb 13, 2007 | 12:05 AM
tranyinstaller's Avatar
tranyinstaller
bore is 87.5mm and its got a 83mm stroke. and that is the same2.0 dohc or sohc ( 420a or a588 ).
