97 4dr engine error codes & how to diagnos
ok my 97 neon is a 2.0 sohc i believe. NOTE this car has about 65k-75K miles on it. nowi did the key on and off 3 times and i got the code 43 and 44 and there were 2 more but they dont matter.
#43 is a multiple cylindar misfire detected. peak primary circut current not achieved with maximum dwell time.
#44 is batter temp sensor volts malfunction. problem with the battery temeperature voltage circuit in the pcm.
my question is how do i go about checking these two error codes and determining what my problem is and fixing it without going to a dealer and getting charges $800 just to look at it and tell me there is something wrong.
all your help is greatly appreciated and i want to thank you in advance.
A Code 43 most likely means you need to change your spark plugs and inspect your wires/coil pack for frays or cracks. When was the last time you did?
I wouldn't worry about the code 44. Is your battery temp sensor still attached?
well i just bought the car from my dads ex-girlfriends daughter and i believe she had the car in the shop once and they replaced the coil pack and maybe the wires but i dont know about the sparkplugs. ill have to check it out in a bit and find out. i dont know where the battery temp sensor is is that something i should just disconect or what should be done with that
ok sorry it took me so long but this car needs the tranny to be replaced and now i got a tranny out of another neon i got and i am starting to tear it down to the tranny and i noticed that that battery temp sensor wasnt even conected to they battery tray, it was pluged in but hanging upsidedown under the tray. and the little nut that would hold it to the tray was missing so it lust have vibrated loose or something. would that really cause it to run like ****? or what does that bettery temp sensor even do? can i just unplug it? well im in the garage so im gonna take the tranny out today and throw the new one in and ill get back to you on this.
thanks, Micah
thanks, Micah
The battery temp sensor won't affect how the car runs at all.
Trending Topics
ORIGINAL: micahman
so basicly that code is worthless. how do i know if it is working or not. does it even matter if that sensor is working?
Yup, the code 43 is generally plugs and/or wires. The wires on mine looked good on the outside but were chard with carbon and arcing on the inside of the plug boots.
I’m not sure why they have a battery temp sensor I’ve driven my car from -45 degrees to + 110 degrees and never had it code. You would have to have a major short to heat things up to get a battery temp code, I would think you would have other issues prior to the 44 code.
