Acceleration Issues...
Old Feb 20, 2007 | 03:06 PM
Durnald_Toad's Avatar
Durnald_Toad
Default RE: Acceleration Issues...
Maybe, look under the back pass door...
Mine has a filter in that location. I found it by seeing it on another Neon
Old Feb 20, 2007 | 03:08 PM
FastNeon84's Avatar
FastNeon84
ORIGINAL: spudsterier
thats just because of the gearing in your trans.....its like starting from a stop sign in 3rd gear
yea but it never used to do that before.
Old Feb 20, 2007 | 03:28 PM
prplhaze's Avatar
prplhaze
Are smelling any exhaust, or rotten egg kinda smells.? I would check the exhaust and make sure its flowing out of the muffler good.Im assuming it has the problem all the time.? Or does it come and go.? Do you have any check engine lights on.? Does the car idle fine? or does it seem like it may be missing.?
Old Feb 20, 2007 | 03:50 PM
96 srt4's Avatar
96 srt4
i would guess it is either an O2 sensor or tps. i had that problem on a 94 duster and an O2 sensor fixed it.
Old Feb 20, 2007 | 03:53 PM
FastNeon84's Avatar
FastNeon84
dont smell anything rotten(thank GOD) exhaust sounds fine...u know....ill go outside and post a vid....maybe that would better explain it
Old Feb 20, 2007 | 06:36 PM
tattoosgurl's Avatar
tattoosgurl
I found the fuel filter location, it's about 10 inches from the pass tire, haven't changed it yet, but plan to. My prob is def not the exaust so i won't answer those questions as they do not apply...
I do however have a new problem a little off topic... when i open my door, it clicks from the fuse panel. a constant loud ticking, louder than the signal light but same rhythm... fuse going possibly? it goes away when i slam my drivers door shut. I know it's telling me there's something wrong but i'm not sure what... it started last night.
Old Feb 20, 2007 | 06:40 PM
das2123's Avatar
das2123
Does the door ajar light up in the dash when the door is open? If not, a fuse or bulb should be replaced.
Old Feb 20, 2007 | 06:44 PM
tattoosgurl
i didn't see any lights on cause it clicks even when the car is off. would replacing the fuse take away the clicking?
Old Feb 20, 2007 | 07:08 PM
das2123's Avatar
das2123
Relays click. Can you find out where its coming from?
Old Feb 22, 2007 | 01:26 AM
tattoosgurl
the clicking was the bottom switch/ button on the frame of my door. i disconnected it and now it's fine... i lose my dome light, but it never really worked well anyway
