Acceleration Issues...
Old Feb 19, 2007 | 09:29 PM
tattoosgurl's Avatar
tattoosgurl
Default Acceleration Issues...
Ok, here's my problem.... i try to accelerate sometimes and have to put it to the floor to get going a good speed, Especially when going from a stop up hill. i don't think it's the fuel pump itself. I am going to change the fuel filter and see if that helps.. just wanted to know if anyone else has any other suggestions for my problem[&o]
Old Feb 20, 2007 | 12:30 AM
spudsterier's Avatar
spudsterier
Default RE: Acceleration Issues...
possibly a head gasket...or a vaccum leak
Old Feb 20, 2007 | 12:33 AM
tattoosgurl
oooh, ugh... that's cuss words to me.lol. but thanks i will have to have it looked at i guess. I am the third owner and i bought it at 180 000 kms.... so i don't mind the money put into it. i love my car
Old Feb 20, 2007 | 12:38 AM
spudsterier
take care of your car and it will take care of you
Old Feb 20, 2007 | 12:41 AM
tattoosgurl
it's my fault, i drive her hard and she still hangs with me she's a good girl, i don't mind fixin her.. it's the first car i have bought. this is only the second problem i have had, last time it was stalling, it was just an oil switch when we thought it may be the pump, so lets hope this is a cheap fix
Old Feb 20, 2007 | 06:26 AM
FastNeon84's Avatar
FastNeon84
my car kind of does the same thing....if im at a low rpm in 3rd or 4th gear....it takes forever to gain momentum....especially when going uphill.....it can possibly be a clogged cat(?)...thats what i think my problem is.....but ill see when i change the exhaust out.
Old Feb 20, 2007 | 08:32 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
when i went to get a fuel filter for my neon they said it didnt have a fuel filter and or it was built onto the pump itself . . . i have the plastic style tank who know good luck and like fast said could be the cat also
Old Feb 20, 2007 | 11:59 AM
spudsterier
ORIGINAL: FastNeon84
thats just because of the gearing in your trans.....its like starting from a stop sign in 3rd gear
Old Feb 20, 2007 | 01:56 PM
tattoosgurl
I have the 4 door highline with the metal tank. thankfully parts are cheaper for it when it comes to fuel. I really don't think my issue is an exaust problem or air intake... i found that today it didn't "feel right" like more of a chug, like it's working really hard, more vibration and louder. it wasn't as cold as usual either.
If the fuel filter is internal, does that mean that my whole system will have to be taken apart to get at it?
Old Feb 20, 2007 | 02:16 PM
das2123's Avatar
das2123
A combination fuel filter and fuel pressure regulator is used. It is located on the top of the fuel pump module. A separate frame mounted fuel filter is not used. The electric fuel pump is located in and is part of the fuel pump module, which is in the gas tank.
