udp
Old Mar 13, 2007 | 10:44 PM
93 tona's Avatar
93 tona
Default udp
i cant get my harmonic balancer back on, it a 96 dohc i did all the head gasket, and its like thebolt is to short, i even tried hitting back down with a rubber mallet and nothing any one had this problem. oh and i did go get another bolt and that didnt help either.
Old Mar 13, 2007 | 10:58 PM
FastNeon84's Avatar
FastNeon84
Default RE: udp
i dont think you can use a hammer to get it back on.....it needs to be pressed on so ull need that harmonic balancer installer/puller to get it on. they cost $ 60 to rent at auto zone, and you get your money back when you bring the pulley back
Old Mar 13, 2007 | 11:06 PM
neisg1's Avatar
neisg1
Default RE: udp
Don't hammer it!!
Have a read through this thread.
https://dodgeforum.com/m_726275/tm.htm
Old Mar 14, 2007 | 12:14 PM
das2123's Avatar
das2123
Default RE: udp
Title says UPD, in the post you say harmonic balancer...which one is it? Stock or aftermarket?
Old Mar 14, 2007 | 01:42 PM
racerx55's Avatar
racerx55
Default RE: udp
same difference.....
Old Mar 14, 2007 | 01:56 PM
das2123's Avatar
das2123
Default RE: udp
ORIGINAL: racerx55
Not really. If its aftermarket, then he can put it in the oven, heat it up, then throw it on there. Can't do that with stock.
Stock crank pulley is not a UDP either.
Old Mar 14, 2007 | 02:35 PM
prplhaze's Avatar
prplhaze
Default RE: udp
I found an easy way to do it, after 3 attempts at it. First off...you MUST heat it up in order to get it to slide on there.I used a portable torch and heated in a circle pattern around the bolt for about 15-20 seconds.Then I used an electric impact gun, and to my suprise it drove it right on there... Doing it any other way will lead to frustration and broken tools. Good Luck
Old Mar 15, 2007 | 02:32 PM
93 tona's Avatar
93 tona
Default RE: udp
o great now i get back on to read it. i took a piec of super fine emery cloth to the harmonic balancer. and no body believed me that the crankshaft swelled. it didnt but thanks for that heating p tip that makes sense.
