indiglow gauges
Old Mar 17, 2007 | 11:54 PM
javon's Avatar
javon
Default indiglow gauges
i have the reverse color indiglow gauges and i am trying to figure out how to connect them there are 2 wires one red and black where can i run them to to get power to cut on and off
Old Mar 18, 2007 | 12:11 PM
spudsterier's Avatar
spudsterier
Default RE: indiglow gauges
hook the black to any ground.....then use a haynes manual to find the wire that suppliespower to the lights in the gauge cluster that way the glow overlay will only turn on when the lights are on....i cant remember what color the wire is
Old Mar 18, 2007 | 11:20 PM
neonracer1010's Avatar
neonracer1010
if i remember correctly when i put in my tach i think its an orange
Old Mar 18, 2007 | 11:29 PM
Ozni's Avatar
Ozni
I just pigtailed mine into what ever turned on when I pulled parking lights on basically which was my ash tray light. I had mine custom made at speedhut.com its got Grim Reaper over the RPM gauge white cluster reverse E glo to and man they look sweet especially blue at night the Grim Reaper Glows himself too.
Old Mar 19, 2007 | 12:42 AM
FastNeon84's Avatar
FastNeon84
your indiglos didnt come with an on/off power switch, mine did..but i ended up getting a whole new cluster cause it messed my needles up, so be careful
Old Mar 21, 2007 | 03:07 AM
BadBrads97Neon's Avatar
BadBrads97Neon
can you install a new gauge cluster, say the white gauge cluster, that has a tach on it if my stock cluster doesnt?
Old Mar 21, 2007 | 04:20 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
you can get a cluster with a tac on it , its plug and play.
Old Mar 21, 2007 | 04:38 AM
BadBrads97Neon
so are there wires that are behind my cluster now that are just useless until I want to put a tach on it? Also is the cluster with the tach only for MTX or can I put it on my ATX now? Cause next month im swapping transmission anyway I am just wondering if the tach will work on both. I think it will I just wanted to get some other input. Thanks
Old Mar 21, 2007 | 10:23 AM
spudsterier
the tach will work on any of our neons.....mtx and atx....its the same cluster and same wiring
Old Mar 21, 2007 | 11:08 AM
neonracer1010
what all do you gotta do to put a 2nd gen cluster in? lets say one outof a r/t or an srt4 one.
