stuff for autocross
Old Mar 20, 2007 | 12:26 AM
civiceater88's Avatar
civiceater88
Default stuff for autocross
ok guys i have a autocross race the 15 of spril and i wanted yalls input on what i should get as some what basic if not alittle more then that for this race.....i have an idea but i would like your input
Old Mar 20, 2007 | 12:35 AM
das2123's Avatar
das2123
Default RE: stuff for autocross
Depends on what class you are running and their classifications.
Old Mar 20, 2007 | 03:34 PM
civiceater88
well say it was the beginner class and there was the normal classification for a autocross race
Old Mar 20, 2007 | 03:37 PM
das2123's Avatar
das2123
No, what I am saying is you need to check with your local SCCA and see what their rules are for Autocrossing. Some don't allow any mods at all or you are limited to what you can do.
I don't know alot about it, since I don't do it.
Old Mar 20, 2007 | 03:54 PM
civiceater88
man dam alright......well if they did allow whatever mod u wanted towhat would u suggest
Old Mar 20, 2007 | 04:13 PM
das2123's Avatar
das2123
Suspension would be key, so sway bars are a must, good struts (Konis, then KYB's), a small drop and run your camber at about -1.5° in the front.
After that, the basic mods...CAI, UDP, ATX TB and so on.
Old Mar 20, 2007 | 07:44 PM
Leonheart17240's Avatar
Leonheart17240
if you plan on racing in the stock class then you need a stock car, down to wheels... you should get on the webpage and read the rules on the classes, i wanted to run my neon in the stock class but i have aftermarket struts and lowering springs, BBS wheels and exhaust, and some other things, and now i havta run in the modified class...
Old Mar 21, 2007 | 01:07 AM
rrwertz's Avatar
rrwertz
I started out in g stock, went to sts, then to street prepared.
main thing to worry about is TIRES. I don't care what you drive, tires are key. then worry about other things. I love autocross. nothing like spanking some douche in his porsche !
Old Mar 21, 2007 | 01:10 AM
BadBrads97Neon's Avatar
BadBrads97Neon
ORIGINAL: rrwertz
sounds mighty fine to me..
