Swap Update! MORE PICS!
Old Apr 1, 2007 | 02:38 PM
NEONRT98's Avatar
NEONRT98
Default RE: Swap Update!
Hmm, well thats not looking so good on my part at the moment.. I just took a look at the FSM for the SRT-4, and the FSM includes the 2.0L cars too... Well, the 2.4L have the T850, and any other model has the T350 w/ hydralic clutch... Im really starting to this this wont work, but its worth a try.. I have heard also that the SRT-4 clutch will not swap into the 1st gens, which means the bellhousings are probably completely different, or its just the flywheel... I will bother that road when I come to it though.. I want to get this interior done today... later!
Old Apr 1, 2007 | 04:47 PM
das2123's Avatar
das2123
ORIGINAL: NEONRT98
You heard wrong then. It will work with some modifying...
ORIGINAL: JeffB#2
SRT[/b]-4 clutch[/b] modified to work with a "Neon" and PT Cruiser NVG-T350 5-speed, all years 3.55 and 3.94 gear ratios. This would be a low-buck "upgrade" beyond a PT Cruiser clutch[/b] for boosted and nitrous cars. You must use an SRT[/b]-4 throwout bearing, the "Neon"/"PT" bearing is a different design and will not work well with the SRT[/b]-4 pressure plate finger design. Will work in hydraulic or cable actuated cars. SRT[/b]-4s are making in the 300WHP area and nearly 400WTQ on stock clutches all over the country. An SRT[/b]-4 pressure plate and disc will not work on a "Neon"/"PT" flywheel, the friction area is too small on the flywheel and the pads where the SRT[/b]-4 pressure plate would bolt on are in the way, are spaced wrong and the bolt/rivet holes are in the wrong location
Old Apr 1, 2007 | 06:36 PM
rrwertz's Avatar
rrwertz
I have one already modded. buy it!
Old Apr 1, 2007 | 06:39 PM
das2123's Avatar
das2123
ORIGINAL: rrwertz
I want it....just can't afford it right now
Old Apr 2, 2007 | 02:23 AM
NEONRT98's Avatar
NEONRT98
Update: Interior is finished! Hopefully I got everything wired up correctly and didnt forget anything! I just need to put the CD player in, make another stop at the yard and get a dash peice.. and thats about it... I got the carpet in, and it took about 2 hours to do just that! I dont suggest recarpeting your car unless its absolutely necissary! Once again, once I get the cable, I'll have a butt ton of picture for ya'll.. Prolly gonna get it to the body shop this week, horray!
Old Apr 3, 2007 | 07:24 PM
NEONRT98's Avatar
NEONRT98
Alright, got the cable, here are some pics!
K-Frame 1, K2, K3
Before Dash Started
Dash 1 Dash 2 Dash 3
Dash Gap Driver, Dash Gap Pass
Engine Test Fit 1, ETF 2
Thats all I have on the phone right now.. I will take some more of the completed interior tonight when I get home. Sorry about the quality, its the best I can do!
Old Apr 3, 2007 | 07:40 PM
spudsterier's Avatar
spudsterier
wow...you really ruined that poor car....j/k
ever find anything out about that tranny????
Old Apr 3, 2007 | 07:44 PM
NEONRT98's Avatar
NEONRT98
Hey, it looks good now! No, I am waiting til I get a shop to take it out of my garage, then I need to get my engine hoist back from a friend and take the tranny off...
Old Apr 3, 2007 | 07:51 PM
BadBrads97Neon's Avatar
BadBrads97Neon
Hey man it looks really good. Nice job!
Old Apr 3, 2007 | 07:52 PM
das2123's Avatar
das2123
Those pics need to be in high resolution. Looks good.
