1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
My Perpetual 76 Project Thread
Old Sep 4, 2013 | 08:34 PM
  #191
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Anything I need to worry about in there?
Old Sep 4, 2013 | 08:39 PM
  #192
crazzywolfie's Avatar
crazzywolfie
i don't think the oil would hurt anything. just try to aim for metal parts that look like they are suppose to move.
Old Sep 4, 2013 | 08:46 PM
  #193
dodge dude94
Got it. I gotta try and get that cap out of the way more, hard to get at stuff because of the giant a/c line in there.
Old Sep 5, 2013 | 01:12 AM
  #194
merc225hp's Avatar
merc225hp
Use oil as posted but make sure you get as much out as possible when done. To me the tag is a indicator for a rebuilt part. Use whatever you need to to get the plate to move IE screwdrivers, pliers, if you have to remove the pick-up mark the pick up to the base then remove it from the dizzy to give you more room to work.
Old Sep 5, 2013 | 01:20 AM
  #195
dodge dude94
Shot some pictures of the carb, and a video, gotta wait on that though.
Casting number
Secondaries.
Primaries.
Oh yeah, and one of the dizzy
Got it.
So what am I looking for? Looks like I'll have to remove the pickup coil from the dizzy here.
Old Sep 5, 2013 | 01:28 AM
  #196
merc225hp's Avatar
merc225hp
There will be a arm or shaft that comes out of the vac pod and goes to a plate, that plate must move freely, it might be under the fixed plate or on top of it, too hard for me to tell from the pix. Try moving the shaft/rod first before you take anything apart if you can. needle nose, forceps, whatever you can use try it.
Old Sep 5, 2013 | 01:45 AM
  #197
dodge dude94
Okay. And I have to take the pickup out, right? Looks like the reluctor would have to go too, correct?
I had a thought about how to test the advance pod: remove it from the dizzy housing, put the cap back on the dizzy, and start the engine. Now, working properly it shouldn't do anything, but applying throttle should make it move if it works, correct?
Old Sep 5, 2013 | 02:09 AM
  #198
merc225hp's Avatar
merc225hp
You might not have to remove anything if it moves, if no movement yep you will be taking all apart. I will see or you can look for a dizzy break down pdf or sheet, check your manual for this info if you have one. Start the motor, 1/8-1/4 throttle, remove the vac hose from the dizzy it should slow down or stumble, then plug it back on the motor should pick up rpm if the vac advance is working.
That would be one way to test it, you can buy a handheld vac pump for like $10 up here this would tell you all.
Old Sep 5, 2013 | 02:11 AM
  #199
dodge dude94
It looks like that entire plate is solid, is there something underneath that or is that entire plate thing the pickup?
So on tap for tomorrow is: make sure the engine starts and runs after the cleaning, then test the vacuum pod, then attempt to make sure the advance stuff in the dizzy is mobile.
Old Sep 5, 2013 | 02:19 AM
  #200
merc225hp's Avatar
merc225hp
Here is a ez test, find a vac port on the carb that has full vac at idle, then plug the vac hose from the dizzy onto that port. the motor should speed up. I should have remembered this test long ago sorry. There might be three plate in there one under and one on top which one moves for the timing advance I can't say. They will all be removable they must be so as to be able to change the upper shaft bearing. How far you have to take it apart to get to that plate could be a pita as the bottom gear and shaft might have to come out.
