tranny?
Old Jun 14, 2007 | 07:34 PM
89d100man's Avatar
89d100man
Default tranny?
I have an 89' dodge w/ a three speed auto/42rh. Does anyone know if a 727 or a 904 would swap with it? Any help would be much appreciated, thanks.
Old Jun 16, 2007 | 12:56 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: tranny?
You would need other 3speed, the 904 is a 4speed auto and you would need the wire harness and pcm for it.
Old Jun 18, 2007 | 12:22 AM
89d100man's Avatar
89d100man
Default RE: tranny?
Ok I appreciate the help. I have another question would a crate 360 from Jegs bolt into my engine bay or is it more work than it is worth.
Old Jun 21, 2007 | 07:51 PM
charginram's Avatar
charginram
Default RE: tranny?
i hear bad things of the mopar crate motors! if you buy one, take it apart and make sure it is assembled correctly and make sure it is clean.....
Old Jun 29, 2007 | 11:39 PM
grcforce327's Avatar
grcforce327
Default RE: tranny?
You guys have it backwards.The 42rh is a 4sp auto rear drive hydraulic w/lockup,and the 904 is the 3sp auto with or without lockup depending on model.No harness for the 904 unless you have a lock/up style with one wire plug rear of case driver's side(very simple).
