Any way to get d150 drop spindles?
Old Feb 29, 2008 | 02:42 PM
  #91
racer9's Avatar
racer9
Default RE: Any way to get d150 drop spindles?
On another site they're saying the late 70's New Yorker spindles will drop the truck 3". Anyone else heard about that?
Old Feb 29, 2008 | 03:37 PM
  #92
mrbelvedere's Avatar
mrbelvedere
what website is saying that id like to read about it
Old Feb 29, 2008 | 03:39 PM
  #93
daomen4ever's Avatar
daomen4ever
ORIGINAL: racer9
ORIGINAL: daomen4ever
how hard is it to do a axel flip?????????????? an what do i need to do
Not hard; http://ramchargercentral.com/boards/...owtoshow;id=17
Basically you remove the u-bolts, and the spring shackle bolts, and drop the springs enough to get the brake drums/backing plates through between the spring and frame. Put the shackle bolts back in, and install the new spring saddle under the axle, new u-bolts, and check pinion angle. Tack the saddles in place tighten the u-bolts and go for a ride. You will need a new lower shock mount too. Thats the simplified version.
were can get new lower shock mount at
Old Feb 29, 2008 | 03:45 PM
  #94
racer9's Avatar
racer9
ORIGINAL: mrbelvedere
http://board.moparts.org/ubbthreads/...=0#Post3939021
Old Feb 29, 2008 | 06:27 PM
  #95
racer9's Avatar
racer9
ORIGINAL: racer9
These guys have a complete kit, and I believe they will sell parts. http://board.moparts.org/ubbthreads/...=0#Post4235480
Old Feb 29, 2008 | 08:17 PM
  #96
Rampant 150's Avatar
Rampant 150
Check this out.
4/6 drop for 819.00 = shipping.
  #97
Rampant 150
Sorry +shipping.
Old Feb 29, 2008 | 08:27 PM
  #98
84 Ram's Avatar
84 Ram
I finally got my spindles and springs todat I think I wil go out tommorow and do a test fit to see if I will get enough drop out of the setup I bought (2" drop springs 2" drop spindles).
Old Feb 29, 2008 | 08:36 PM
  #99
Rampant 150
This guy just put spindles on his 73 club cab. Pics and everything.
Old Feb 29, 2008 | 08:47 PM
  #100
84 Ram's Avatar
84 Ram
I don't know if I have posted pictures of my truck on here or not but here it is. I know it looks rough but I am working on that. It is a 318 four speed truck with a 8 3/4 rear with 3.91 gears. I am also in the process of building a new motor well I'm actually building the motor thats in it. I am stroking the 318 and making it a 390 gonna run 9.5 compression with "J" heads and a 280 duration 480 lift cam.
[IMG]local://upfiles/73712/1E49C1A281B84B6F863AD228B8534562.jpg[/IMG]
